Author Topic: BK Precision 8602 Battery test mode  (Read 709 times)
Offline gasmeterTopic starter
« on: May 29, 2019, 08:42:52 am »
Hi all I wonder if anyone can help.
I set up an over night battery capacity test using the built in function.
I set the limit params , although why time has to be set seems silly to me .
I got in this morning and it had completed and was happily showing my timeout period and the capacity I told it to stop at.
So I looked at it and asked soooo.... Why are you telling me the information I entered ?
I know it can't have hit the capacity and timeout at the same time (pretty sure it didn't get anywhere near the lower voltage) .
So how do you tell when you come back in the next day which parameter caused the test to end ?, given that its displaying both the timeout period I entered and the capacity stop value.
The manual doesn't help at all !
Peter
Re: BK Precision 8602 Battery test mode
« Reply #1 on: May 30, 2019, 04:35:11 pm »
It worked second time around.
