Just yesterday, I got an old BK Precision model 120p multimeter at a local thrift shop for $5. I think Dave's fascination of vintage/antique test equipment has gotten to me. The multimeter didn't include any test leads, so I haven't been able to see if it works yet, and even if it did come with leads, some (all but one really) of the battery connections are either corroded or disintegrated.
The meter did come in what I assume is its original carry case and instruction manual. Both have seen much better days, as you will see.
I'll state right now that I really don't know too much about electronics; I can use a multimeter correctly without overloading it, I can setup a scope without using the "auto" button, I can (and still am in the process of) make a stepper motor-driven tachometer with an arduino, but I don't know enough about anything else to make any kind of meaningful comments on the pictures I've taken, so I'll only comment of one or two of the pics.
Many of the pictures are duplicates with and w/o flash so you can see different details in different pictures.
I'll apologize in advance for the picture quality; I took these with a Canon 20D that has about the same image quality as a modern-day cell phone.
Enough talk, let's get started!
Yes, that is mold on the instruction manual. I'm quite sure this meter has sat in someones garage or basement for about 30 years. The pages inside are just as bad; I scanned the whole manual.
There's the disintegrating 9V battery connector. And to think I, just a month ago, took apart an alarm clock and threw out the 9V battery connector it had. That'll teach me not to throw anything away.
These were the batteries that were in the meter. About what you would expect with their age... The D cell measured 100mV, the 9V measured 10mV. The 9V battery was still connected to the meter when I opened the battery compartment. I tried my best to delicately remove it, but the negative wire from the connector broke off, the corresponding clip was stuck on the battery and had some disgusting resin-like substance on it.
Last used around '83... I wasn't even born then.
Four machine screws into threaded inserts with only one missing lock washer.
Now for the close-ups!
Now the scans of the instruction manual
Here's a link to the photobucket album:
http://s1276.photobucket.com/user/Glaveyy/library/bk%20multimeterWell, that's all folks, I hope you enjoyed yourselves.
