Author Topic: DS2072A-S hackable or not?  (Read 10819 times)
Offline benjamin125Topic starter
« on: April 23, 2014, 02:42:50 pm »
Hi
I would like to buy an oscilloscope DS2072A-S. I want to know if this  model is hackable??? I already know that the DS2072 and DS2072A is hackable.
Thank you
Offline hans
Re: DS2072A-S hackable or not?
« Reply #1 on: April 23, 2014, 03:08:20 pm »
My DS1074Z-S is hackable with the DS1000Z(which is similar to the DS2000/4000) generator.
But I believe the hacking method is different for the DS2000A series, so don't quote me on that for those scopes.
Offline BTO
« Reply #2 on: April 27, 2014, 06:32:30 pm »
That is Correct
I have a DS2072A Upgraded from 70Mhz with Trial options to 300MHz with all options licenced
the Upgrade process for the DS200 and DS2000A series Differs from the DS1000Z series
they ARE different
they are different in hardware Specs
Regarding DS2000A-S  and DS2000A
well, I havent tried it myself
but.. after reading the entire forum Post on all this
and learning the differences between the DS1000  DS1000Z  DS2000 and DS2000A and the DS2000A-S
in my opinion i don't think it'll be aproblem
after all the DS2000A-S is the same hardware as the DS2000A family of Scopes therefore the upgrade will work
i would give you about a 99.99% Chance of success
besides,  if it doesn't work
You can always revert back to your previous Firmware
QUESTION EVERYTHING!!!
Offline AintBigAintClever
« Reply #3 on: April 29, 2014, 10:49:24 pm »
Partial (well, almost total) success on my DS2072A-S.
00.02.01.00.03 (licence key dump): All options unlock OK, but any attempt to crank up the bandwidth fails; NSEH is the only DS2072A code that works.
00.03.00.01.03: Options unlocked above remain unlocked, still won't increase bandwidth
00.02.01.00.03 (patched for non-A keys): SUCCESS! DSCA enabled 300MHz, DSHH enabled all options
Serial: DS2E1xxxxxxxx
Hardware version:1.2.2.0.2 (shows as 2.0 on the "normal" information screen)
FPGA version:
SPU: 04.00.07
WPU: 01.01.03
CCU: 12.29.00
MCU: 00.05
Many, many thanks to those who made the hack possible!  ;D
« Last Edit: April 29, 2014, 11:10:57 pm by AintBigAintClever »
Offline samertje
« Reply #4 on: May 12, 2014, 01:42:55 am »
I'm going to buy a DS2072A-S and try..
Offline bnred777
« Reply #5 on: July 08, 2014, 07:15:04 am »
Hey guys, I just bought the DS2072A-S and I wondering if anyone ever got the 300Mhz hack working with full options? If so, does the DS2000A Upgrade Utility work for getting the options/bandwidth?
Thanks
« Reply #6 on: July 08, 2014, 07:54:06 am »
Yes. One of the other guys suggested doing two separate licence installations using Ultra Sigma to send the commands.
Original post here. Mine's now using the latest, non-hacked firmware in conjunction with NS8N and NSEH keys to unlock everything including 300MHz.  :)
« Last Edit: July 08, 2014, 07:56:01 am by AintBigAintClever »
Offline bnred777
« Reply #7 on: July 09, 2014, 05:36:55 am »
Thank you very much for the reply!
Offline PepeK
  • Country: sk
« Reply #8 on: August 05, 2014, 09:13:32 pm »
Has somebody hacked the scope DS / MSO 2072A having  SW  00.03.00.SP1   and   HW  2.2  via downgrade to modified 00.02 and upgrading back to 00.03 after entering license codes ? As I understand, it works only for HW 2.0 and not for HW 2.2.  Is it true ?
Thank you.
Offline milek22
« Reply #9 on: August 12, 2014, 03:12:20 am »
Hello Gentlemen,
I bought a DS MSO2072A-S and need help:
As above - SW 00.03.00.SP1 HW 2.2.
The SIGMA ULTRA calls me a serial and version. No big HEX.
I read something about the logical interface. Upgrade utility does not work on higher versions.
Please help me how to dump the HEX file?
What can I do to unlock my MSO2072A.
Thank you in advance
« Last Edit: August 12, 2014, 03:51:50 am by milek22 »
Offline PepeK
  • Country: sk
« Reply #10 on: August 12, 2014, 09:31:04 am »
"Big hex" is shown only if you have patched firmware.
Open your scope and use JTAG adapter ...
Offline milek22
« Reply #11 on: August 13, 2014, 08:14:14 am »
1 What is the processor in MSO2072A?
2 What is the eeprom in MSO2072A or DSO2072A?
Thank you very much.
