These ISOs work for the 16702B as well, right? All the 16700 series Logic Analyzers, right? Thanks!
Yes, the final version B3760_14243 A.02.90.00 will install on all of the 16700 series (16700A, 16702A, 16700B, 16702B).
If you install on one model then then move the drive to a different model some weird things may happen and some things might not work right. Some things seem to be configured for the specific model only during the installation process and not dynamically during every boot after installation. I've never looked into what it might take to manually reconfigure things for different models after installation. I've never had a reason to do that.
