Yes..the title says it all.
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
Anyhow, I thought I'd make a new post cuz there's a 'gotcha' with the new DS2072A , HW 2.0 , FW 3.0 SP1 which I just got 2 days ago, brand new.
Ok....the full options upgrade doesn't brick the unit. So don't worry...the recent FW upgrade did. This one....not that it's bad or anything.
http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-001a/t/page/fm/0I'm telling this backwards to answer the most pressing matter first....bricking
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
.The DS2072A responded to my inserting a 4MB flash with the latest FW by a pop up - 'New FW detected' ; Install?
You get a soft button OK/cancel option. Well, I chose 'OK' (smart scope, I thought) .....a progress bar pops up and after about 75% (3mins) it gets stuck
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
. 1 hour later it's still stuck. By this time I have discovered this instruction document on the same page of the FW, duh...
http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-001a/t/page/fm/0Ok, I bite the bullet and reboot...naturally bricked at the RIGOL splash screen.
Unbricking:
Follow the instructions in the FW PDF....they work. Unbricked in 3 mins.
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
Also..all prior 'upgrades' still in place.....on to that..To summarize the simplest upgrade path:
1) Post #3668 here:
https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/3660/ execute the instructions to get the 'scope binary dump, USB conn. works fine. U should run the 'Rigol USB.exe' utility with admin privileges to make the binary file:ds2072a.bin
2) DL the rigup 0.4 file from this post.
3) Copy the binary file (ds2072a.bin) into the folder u extract the rigup.exe and open a DOS window there to execute this cmd: rigup ds2072a ds2072a.bin
4) Now u have your option keys, note the black pic attached.
5) Execute the Rigol Ultra Sigma utility....(should be on your Scope CD or get it from Rigol's site)
http://www.rigol.com/download/China/DG/PC_SW/Ultra%20Sigma(PC)Installer.rar6) Note the pic with the Ultra Sigma instructions to update the 'scope.
When entering your key...leave out the NS8H: and all the dashes in between the 4 sets of 7 alpha numerics. You get one continuous 28 char. entry.
Execute Send and you're done....scope does a quick progress bar and auto reset.
Thanks to all those who made this possible, you rock!
![Fighting :box:](https://www.eevblog.com/forum/Smileys/default/fighting0030.gif)
PS:This 2072A came with FULL 300Mhz probes, RP3300A , 10X units. Quite the value from Rigol!
