Definitely lost in the sea of bytes of my DS2102A.
Trying to use the string:
:SYST:UTIL:READ? 15441920,13262848
or so to dump the memory of my scope, I used the nmap scanning program as per instructions of some post ago, but it returns an error, but the lan connection is ok.
Then I tried to use the Ultra Sigma SCPI program and it works with other commands, but sending the string:
it returns an error.
I also investingating in the DS2000A programming guide to understand more precisely how to send commands to my scope, and found that only SYST is a documented command; no trace of UTIL and READ, perhaps they are undocumented commands.
But the realty is that the Whole command doesn't works for me
I hoped the well explained step by step process that Bigone 5500 wrote some posts ago would work, but nothing
So, please help: what is the trick?
