Hi everyone, I finally got my scope! Now it's time to hack it! lol... I tired to use the ds2000a upgrade utility but when it got to the part where you plugin the scope to the computer it doesn't find the DSO. I have read the forms and tried several things, including a different computer. I downloaded the new NI Visa software just for fun and I uninstalled the upgrade utility then loaded the new Visa software for the driver, re-installed the upgrade utility and still no luck. I also made sure that the DSO was set to computer mode in utilities but I tried picbridge just for the heck of it... My software version was 2.01 before and after the loading the file from the usb stick as instructed by the program. Also, my hardware rev is 2.0. Any ideas? I did read one fourm that said to use the front USB port of the scope and set the mode to picbridge... does this sound right? The reason I haven't tried it yet is because I don't have the cable but if you guys/gals think it will work I'll buy or make one. Also, I would like to have the latest firmware version, could someone let me know what the best way of getting the latest rev and having all the options/300mhz still enabled? Just for some more info, I do have a ARM JTAG debugger (Olimex) that I could use to do it the hard way but I'm always up for the easy way first!
Thanks!
