Download link
Mirror 1Could you please replace these two direct download links with these two VirusTotal links instead:
Download link: https://www.virustotal.com/url/029ed60a28546c71f28bf314bfad4e397cab65c6c81020a05b4b7fe735a60b06/analysis/1396511367/
Mirror 1: https://www.virustotal.com/url/62a59092a4c65bff087f185176f6a3460925085de5cde1f9afdb0d58200608ce/analysis/1396511872/
Then you see a virus report before downloading and the file URL are at the top of the VirusTotal pages. And people can also add comments there discussing if there's any false positives or actual trojans/viruses.
You can add any file links here https://www.virustotal.com/#url and it will create a VirusTotal link instead with direct download links and virus reports.
Btw. if you want you can manually remove 'hu/' from the links before posting them to make them a bit shorter and if you don't want people to see you are from Hungary. So https://www.virustotal.com/hu/url/... becomes https://www.virustotal.com/url/...
When clicking the 'hu/' part will be automatically inserted or changed to another language depending on you location.
Thanks, I'm considering buying the DS2072A for the deep memory and the cheap 300Mhz BW. (as second scope)
It doesn't need to be open source (because then other people can make bad versions)
Just find a way to make it not generate 'false positives' !!
That... doesn't make any sense. Anyone can patch a binary or replace a binary in a closed source installer and turn a "good" version into a "bad" version. Open source has nothing at all to do with that.
If good after-sales support is important for you, I can only recommend Silcon Electronics.
The owner, Petr Smid is also an EEVBlog member under the nickname "Drieg". He has tremendous experience with Rigol DSOs, and he is very helpful.
Like many other EEVBlog members, I bought my DS2072a from him an have not regretted it.
BTW, they offer free shipping within the EU
Yes, you are right it still can be made bad, but I'm pretty sure it will be much easier to spot a bad one if there is only one good version.
Wow, what an enormous amount of pissing and moaningabout a tool someone spent their time on, for free, to try to help people out.
Way to say "thanks"!![]()
[/sarcasm]
[/sarcasm]
Specially when the original source is available and linked on the monster thread.
Write your own people and make it open source if you feel so strong about it!
Hey Mark_O and miguelvp
Thanks for the support. It's really nice to see there are some people out there who actually appreciate my effort
BTW, have you already tried the Utility?
I don't understand why asking for source is complaining or even considered ungrateful. I'm not an ass-kisser, if that what you mean by appreciation.
It could not detect the USB-connected scope at that step after loading the custom firmware. Ultra-sigma worked fine. I ended up just doing the upgrade manually.
My PC is running Windows 8.1 x64 and I tried multiple USB controllers/ports. ultra-sigma could see the scope in every case.
stupid download sites
