tried with the procedure described at page 57.
The mA port reads 10K
A port reads 0.10 Ohms instead of 0.50 (using leads form cheap dmm)
A port reads 1.18 Ohms instead of 0.50 (using fused cat III leads)
If i turn off the device and turn it on again, this time test A port first the reading starts jumping up to 0.8 then decreasing slowly to 0.1
if i repeat the measure on mA port the A port will always show 0.1 ohms until reboot.
any idea how can i fix that ?
thx
