Author Topic: Hantek DSO5102P : firmware update ???  (Read 7014 times)
Offline mushroomTopic starter
« on: April 26, 2015, 01:35:44 am »
Despite Dave's video, I recently got a Hantek DSO5102P. I first did a system backup, and then used it a few weeks.
My DSO fw is 3.40.0(140925.0), hw version : 1000xffff8108 ; I think that "140925" means 2014-09-25
Today, I decided to update the firmware.
I searched for files and found two versions :
Hantek Onedrive : 3.40.0(140208.0)
Hantek website : 3.40.0(140806.0)
Firmware updates are not up to date ! Why the hell do they release obsolete firmwares ?
To see how fw updates work, I had a try with 3.40.0(140806.0) fw (older)... It seems to work (displays version correctly), but shows an error screen at power on. 3 options : F1-reboot, F2-recover system, and F3-update the recover partition.
F1-reboot : reboots without any error message, and seems to work ; but the error reappears when cycling power.
F2-recover system : replaced the "update" (older 3.40.0(140806.0) ) with the original one (most recent 3.40.0(140925.0), installed when I received the DSO ), and problem was fixed.
I did'nt try F3-update the recover partition.
Did Hantek release a true fw update ? What fw versions do you have with your DSO5000P ?
« Last Edit: April 26, 2015, 01:38:21 am by mushroom »
Offline edmundopt
  • Country: pt
  • There's theory and practice...
Re: Hantek DSO5102P : firmware update ???
« Reply #1 on: August 09, 2015, 09:26:28 pm »
hi, can you send me that firmware , upload it to zippyshare or something
myne is runing an older version, and I can't find your version to download.
