Hi there,
I own a DS2072A (Hardware 2.0, Firmware 03.03.SP1). When I set the cursor (X and Y, A and B) to a waveform on the scope and then save it as a picture to a USB-stick, the cursors on the saved picture file are not on the same position than on the scope screen !!!
![Angry >:(](https://www.eevblog.com/forum/Smileys/default/angry.gif)
See attached files, one is the saved screenshot, the other is made with a camera as a "evidence".
On the scope screen, the cursor position doesn´t moved after the saving process!
It don´t matter what kind of waveform or what channel is used.
Has anyone a idea what is going wrong, or can verfiy this with his own scope?
