did you run SPC? That should take care of the dc offset. I think that's normal to happen. SPC is required after BW upgrade
First, thanks a lot for explaining. I did not know what SPC was or when to use it. I warmed the oscilloscope up and tried it a few times, but it always failed
![Cry :'(](https://www.eevblog.com/forum/Smileys/default/cry.gif)
error log reported code 280 3 0 0, couldn't find any info about that.
However, I kept trying, turning off all other appliances in hopes to remove anything that could interfere with the process. Still failed, but, believe it or not, when I moved the oscilloscope to another room/power outlet, SPC succeeded!
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
I'm very happy, calibration is spot on! In retrospect, in the past it was off by some tiny amount of mV, too, which bothered me but I didn't know why that was or what I could do.
See your reply, I executed SPC again, and it has been running for 4 hours, but it failed again.
Anyway, This at least proves that it has nothing to do with hacking , Maybe it is a device failure .
It's a year late but maybe this post is still of interest to you...
![Flogging A Dead Horse :horse:](https://www.eevblog.com/forum/Smileys/default/DeadHorse.gif)
