Author Topic: 10x probe recommendation  (Read 3409 times)
Offline HextejasTopic starter
« on: January 27, 2018, 03:04:37 pm »
As the subject states I need one and I see all kinds at all prices. My budget is $20.00 but could increase that if necessary.
My scope is my 1st one, a self made DSO 138.
Offline joeqsmith
Re: 10x probe recommendation
« Reply #1 on: January 27, 2018, 04:02:28 pm »
I bough some Hantek PP150 probes a few years ago.  They are still holding up fine.
https://youtu.be/buG-H_LZH0U
The following users thanked this post: Hextejas
« Reply #2 on: January 27, 2018, 04:12:48 pm »
With that scope, any 10:1 probe would suffice, you can pick them up very  cheaply.
Offline Peabody
« Reply #3 on: January 27, 2018, 05:21:07 pm »
Anything you buy is going to be more capable than your scope.  I found a P6000 probe, which I think is 10 MHz, for about $6 when I built my DSO150, and it works fine.  You'll also find a P6020, P6040,...,P6100 in that price range.  Here's a Bangood offering, also available from their US warehouse for a couple bucks more:
https://www.banggood.com/DANIU-P6100-Oscilloscope-100MHz-PKCATI-BNC-Clip-Probes-Clip-Cable-p-1157611.html?rmmds=detail-top-buytogether-auto__2&cur_warehouse=CN
« Last Edit: January 27, 2018, 05:23:30 pm by Peabody »
Offline Old Printer
« Reply #4 on: January 27, 2018, 07:23:45 pm »
MP Jones in Florida blows out their 20 Mhz 1-10x probes for $2.95 once and a while (right now) and I add a few to my orders. If nothing else its a nice light weight cable with a BNC connector that I attach mini grabbers and alligator clips to for the bench, when I don't need a real probe.
http://www.mpja.com/20MHz-Oscilloscope-Probe/productinfo/15085+TE
Offline Hydron
« Reply #5 on: January 27, 2018, 09:38:55 pm »
The banggood type probes do not use resistive co-ax, they fake it using a ~100R resistor in the compensation box (DC resistance in 1X mode is approx. 100 ohms). This means that anything with a fast edge will ring due to the lack of damping in the cable. Unfortunately this makes them worthless for many uses - I was hoping that any issues with them would be confined to bandwidth or physical quality but they were worse than expected.
« Reply #6 on: January 28, 2018, 01:20:49 am »
Well its always been my understanding that the coax cable was just that coax and the 10:1 was achieved via 1M resistor switched in and out of series with the probe tip via the switch in the probe handle, I have no idea where you got the notion about resistive coax cable and a 100ohm resistor from?
Offline joeqsmith
« Reply #7 on: January 28, 2018, 02:05:04 am »
It's fairly well known.   I think the Hantek probes are still about $10/ea.  These could be used with a better scope down the road.
« Reply #8 on: January 28, 2018, 07:17:02 am »
That's very impressive Joe, so I went and bought one. Not much risk.
I also couldn't make up my mind on the Banggood and the MP Jones so I bought them also. I'll wind up sending 2 back.
Thanks for the suggestions.
« Last Edit: January 28, 2018, 07:21:26 am by Hextejas »
Online tggzzz
« Reply #9 on: January 28, 2018, 08:59:55 am »
Do a spice simulation of a voltage step into that circuit, and watch the transmission line "ring"!
FFI, see https://entertaininghacks.wordpress.com/library-2/scope-probe-reference-material/
Offline Hydron
« Reply #10 on: January 28, 2018, 11:21:32 am »
Thanks Joe, I think i'll grab some of those next time I'm after cheap probes.
For those confused about the 100 ohm thing, if you measure the DC resistance of a probe in 1X mode it'll normally be a few hundred ohms - this is from the (deliberately) lossy co-ax used to damp down ringing from the impedance mismatch such a probe will invariably present to the circuit/scope input.
In the case of the banggood probes (or others which look identical - mine came from amazon) normal co-ax was used instead, probably as it was cheaper, and the probe DC resistance was from a lumped element SMD resistor in the compensation box rather than distributed resistance in a lossy co-ax cable. As the damping resistance has to be distributed to work correctly the probes were absolutely hopeless when measuring fast edges - the reflections seen on the scope were clearly from the probe rather than the circuit. See the links others have given about how probes work - it's not immediately obvious!
