Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
DP100 PD-Power Supply 100Watt [0-30.00V / 0-5.000A) [∼50$]
« previous
next »
Print
Search
Pages:
Prev
1
2
3
All
Go Down
Author
Topic: DP100 PD-Power Supply 100Watt [0-30.00V / 0-5.000A) [∼50$] (Read 25416 times)
Phil1977
Frequent Contributor
Country:
Re: DP100 PD-Power Supply 100Watt [0-30.00V / 0-5.000A) [∼50$]
Reply #50 on:
July 18, 2024, 05:01:30 pm »
Maybe the VBUS is not directly routed from the plug to the chip - I do not know if the chip needs it to do the negotiation or if its just connected to CC1 and just does the "paperwork". I´ll have a look this weekend.
Logged
Phil1977
Country:
Reply #51 on:
July 18, 2024, 07:55:16 pm »
Good news: While the DP100 is powered by non-managed 30V DC, the maximum voltage on the CH224K VBUS pin is 10V, VDD is around 2V. It seems that the device only powers this chip if it initializes the power delivery.
Last Edit: July 18, 2024, 07:56:47 pm by Phil1977
Logged
ha_embedded
icpart
Regular Contributor
Country:
Reply #52 on:
July 28, 2024, 02:41:17 pm »
I just make fast search about good load switch ITS428L2. Seems that be good candiate for that job. It is have all protections inside is, maybe t will not need PCB if can handle load current.
https://eu.mouser.com/ProductDetail/Infineon-Technologies/ITS428L2?qs=sGAEpiMZZMvjbjwkTuU2aZXYNMpOS50Yh7EhO2KKWBw%3D
As I tried figured out that if my DP100 have that undershoot issue time ago I tested it with USB-C charger and my portable OWON hds2202s and there didn't have such problem as I remmeber, but maybe need to test it again.
Last Edit: July 28, 2024, 02:47:26 pm by icpart
Logged
caind
Newbie
Country:
Reply #53 on:
July 29, 2024, 12:38:03 pm »
The ITS428L2 needs at least 4.75 V. You certainly don't want to use the DP100 for output voltages ≥ 4.75 V only...
Logged
Print
Search
Pages:
Prev
1
2
3
All
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
