Author Topic: Siglent SDS7000A 3 and 4 GHz 12 bit DSO's  (Read 70334 times)
Offline tautechTopic starter
Re: Siglent SDS7000A 3 and 4 GHz 12 bit DSO's
« Reply #175 on: February 20, 2024, 08:01:58 pm »
some system infos pictures and options,  not sure  if we could get most of them on purchase package ?
Most options are free as part of an introduction promotional package until mid 2024
https://siglentna.com/news-article/siglent-sds7000a-introduction-promotion/
https://www.siglenteu.com/news-article/siglent-sds7000a-introduction-promotion/
https://int.siglent.com/info/detail-78.html
« Last Edit: February 21, 2024, 01:20:42 am by tautech »
The following users thanked this post: coromonadalix
Offline Martin72
  • Testfield Technician
« Reply #176 on: February 20, 2024, 09:14:48 pm »
Lots of options, much to my delight.
Including some that only lecroy usually has and that we need.
I think I'll have to talk to our purchasing department.
(Kierkegaard)
Offline coromonadalix
« Reply #177 on: February 21, 2024, 03:07:28 am »
loll       done  that  loll    still waiting for an quote answer
I'm impressed, still lot to discover,  still have to master the "unified 4 channels controls"  witch is not my forte  :palm:
Controls are fast and responsive to say the least.
But  another thing:
When you request the "auto setup",  you get an yes or no  popup asking if you still want to do it  ??   witch break a little bit,  the purpose of the auto setup ??
Unless it could be risky for the input stages ??  That should be removed  loll ... trying to see if it's an selectable / removable option  ??
Because the small SDS1204...    dont have this nag ???
« Reply #178 on: February 21, 2024, 03:20:02 am »
But  another thing:
Good feature instead of just applying Autoset when you press it by mistake and it then changes all your scope settings.  :rant:
However if this has an Undo (and it should) no harm is done.
Offline KungFuJosh
  • TEAS is real.
« Reply #179 on: February 21, 2024, 03:22:50 am »
I also hate the autoset confirmation. The confirmation should be optional in the settings.
The following users thanked this post: jasonquin
Offline hpw
« Reply #180 on: February 21, 2024, 06:56:57 am »
Would be a value, if the the Jitter-Kit is included with missing Jit-Kit specification as the Scope Jitter specification.
My 2 cents, otherwise 20K$  :phew:
Hp
« Reply #181 on: February 21, 2024, 10:47:40 am »
P12
https://int.siglent.com/u_file/download/23_12_27/SDS7000A_Datasheet_EN01B.pdf
The following users thanked this post: coromonadalix, KungFuJosh
Offline hpw
« Reply #182 on: February 21, 2024, 05:03:30 pm »
P12
Well, as SDA7000A may looks like a bargain, with unknown performing figures, but how it compares to a WaveMaster 8000HD: Starting from $270,000  :-DD
« Reply #183 on: February 21, 2024, 05:17:15 pm »
sadly  since there is calibration sticker / void,    i can not open the unit :(    they are on screw i did not saw on my 1st attempt  loll      near the foot
« Reply #184 on: April 11, 2024, 05:38:59 pm »
New firmware for SDS7000A models.
Version: V1.1.5.1
270 MB
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS7000A_V1.1.5.1_EN.zip
Release notes
1. Cursor: Supported more cursors, and more flexible cursor combination
2. Fixed several bugs
Includes the previous version changes/fixes:
Supported new probes: Siglent’s SCP5030, SCP5030A, SCP5150, SCP5500
Measure: Optimized UX of Track and Trend; Supported to export measure data
Fixed several bugs
Slow response after pressing Math button
AWG: SCPI cannot set Load
Some bugs of USB2.0 compliance test
Some bugs of 100Base-TX and 1000Base-T compliance test
Some bugs on Options’ unlock
The following users thanked this post: coromonadalix, 2N3055
Offline ddrl46
« Reply #185 on: April 11, 2024, 07:16:25 pm »
Is there any news about the higher bandwidth versions of the SDS7000A being released outside of China?
« Reply #186 on: April 11, 2024, 10:01:56 pm »
Zip.....not that I've asked yet.
I'll try to get a programme.
The following users thanked this post: ddrl46, KungFuJosh
« Reply #187 on: April 12, 2024, 09:51:35 pm »
Nothing definitive, aiming for Q4 is the word.
« Reply #188 on: August 15, 2024, 08:24:50 am »
Finally after a very recent visit to Siglent HQ we were able to spend a little time with a SDS7404A.  :clap:
It's a big scope and reasonably quiet and boots quite fast, no doubt due to its PC based architecture.
The unit I played with was of unknown to me FW which allowed several configurations of the display providing up to 9 windows however as only one window in the attached image was configured to display traces .... but you get the idea.
The following users thanked this post: egonotto, KungFuJosh, Martin72, luudee
Offline Martin72
« Reply #189 on: August 15, 2024, 08:57:48 pm »
It's such a shame that it's so far away from me in terms of price.
Ever since I first experienced it 20 years ago, I've found multi-grid (windows) displays brilliant.
I was all the more “disappointed” when I realized that even today this technology can only be found in expensive scopes.
I thought that if it already existed in Lecroy scopes from the 1990s, then it must not be a problem to implement it almost everywhere today.
If you consider that the Lecroy 93XX scopes had a 16 bit 68000 CPU and a few kB RAM...
But no.
Too bad. ;)
(Kierkegaard)
Offline points2
« Reply #190 on: August 17, 2024, 12:35:33 am »
Hi Martin72,
I've got only a few years experience in electronics (a old diploma in engineering is somewhere  :palm: )
Thus, far from your "20years"...
Question :
with your experience, you're still looking at RT-scope vs >10GHz scopes ?
could you please explain, given that you have a sampling scope at 3kEur (see topic in this forum)... that outperforms these beasts ?
Disclaimer : Siglent SDS7000A is a high-end product, at "nice price", like MXO4s
Just an idea : for any hobbyist that is looking for "more BW" at "nice price" : a sampling scope is a gift...
Offline Martin72
« Reply #191 on: August 17, 2024, 01:09:22 pm »
At home I have what I can afford and then I want the ‘best’ for the money.
And that's what I have. ;)
I certainly don't ‘need’ the SDS7000A, but if I could afford it, I would still buy it.
Because as I said, the best for the money... 8)
Privately, I hardly do anything that requires a high bandwidth, so I could be happy with the SDS3000X HD.
As an old man, I just wish I had a bigger display. ;)
At work we now have projects that require a higher bandwidth, so a 2.5Ghz Lecroy WavePro HD is now on the way.
I would have liked to buy a 7000A for us, but was in the minority, so now a lower bandwidth scope at twice the price.
(Kierkegaard)
