Author Topic: Pico Tech TA131 vs Pico Tech MI103  (Read 785 times)
Offline TraderTopic starter
« on: November 19, 2021, 03:55:54 am »
I bought a Pico Tech TA131, but I received a "Pico Tech" MI103.  Are they the "same"?  Should I return it?   :-//
http://www.saelig.com/product/PSA007.htm
"This product has been superseded by the TA131."
"250 MHz Oscilloscope probe X1/X10
This passive high impedance scope probe has a 250MHz bandwidth and high frequency trimming. A two position slide switch allows attenuation of either x1 or x10 to be selected. Please note that the x10 function will not work with the ADC-10 or ADC-12 as the input impedance of these devices is not the same as a standard oscilloscope."
http://www.analyticalelectronics.com/testequipment/picotech/pc_oscilloscope/passive_probes.html
"MI103 : 250 MHz Oscilloscope probe x1/x10"
"This passive high-impedance scope probe has a 250MHz bandwidth and high frequency trimming. A two position slide switch allows attenuation of either x1 or x10 to be selected. Please note that the x10 function will not work with the ADC-10 or ADC-12 as the input impedance of these devices is not the same as a standard oscilloscope."
https://www.picotech.com/library/application-note/how-to-tune-x10-oscilloscope-probes
https://www.interworldna.com/pico/how-to-tune-x10_probe.php
Thanks.
Offline egonotto
Re: Pico Tech TA131 vs Pico Tech MI103
« Reply #1 on: November 20, 2021, 05:25:56 am »
Hello,
I have a TA131. If you have a question, perhaps I can answer.
Best regards
egonotto
Offline Performa01
  • Country: at
« Reply #2 on: November 20, 2021, 08:41:35 am »
I have no experience with the MI103 probe.
While I have no doubt that it could perform equally well as the TA131, there is a main difference.
MI103 has a separate HF-trim, which you have to get right before you can have a stellar performance from this probe.
By contrast, the TA131 has only the usual LF-trim and is an excellent HF-match for the SDS1000X-E series right out of the box.
To cut a long story short, you need to study the operating instructions carefully and will most likely need a good quality 1 MHz square wave with fast risetime (<3 ns) in order to adjust the HF-compensation correctly.
The following users thanked this post: Trader
