Author Topic: BM235 400 mA fuse question  (Read 1190 times)
Offline rcbuckTopic starter
« on: January 27, 2020, 09:59:58 pm »
I blew the 400 mA fuse in my EEVblog meter. I accidentally put it across a 12 volt, 1/2 amp power source. One pin off on the connector. :(
I have found several HRC fuses rated at 500 mA. That would be an acceptable replacement instead for the 400 mA original.
The question I have is does the internal resistance of the fuse have any affect on the current measurement? The fuses I have found vary from 0.5 ohms to 3.5 ohms. I'm tempted to replace it with a standard 3AG fast-blow fuse as the highest voltage I ever measure is about 40 volts.
Could someone please measure the resistance of the original fuse and post the result here? That would give me an idea of which replacement to buy. The SIBA fuses are unobtainium in the U.S. as far as I can tell. Amazon and Ebay have them but I wouldn't trust either one of those sources.
Thanks.
Offline Yansi
  • STM32, STM8, AVR, 8051
Re: BM235 400 mA fuse question
« Reply #1 on: January 27, 2020, 10:13:12 pm »
SIBA can be probably bought from TME.eu, even in the US of A.
Online Fungus
« Reply #2 on: January 28, 2020, 08:36:01 am »
I'm fairly sure you can buy fuses from the same place you bought the meter from...
Offline ComradeXavier
« Reply #3 on: January 28, 2020, 01:21:55 pm »
I am not a measurement expert, but I wouldn’t expect the resistance of the fuse to affect the voltage drop across the meter’s current shunt in any significant way.
I can’t measure the original because I also popped mine. I found and bought a comparable replacement from DigiKey. Not cheap, but I wanted to meet the markings on the meter so I won’t surprise myself later.
Online Fungus
« Reply #4 on: January 28, 2020, 05:42:47 pm »
No, it won't...
...but 3.5 Ohms might add significantly to the burden voltage of the meter and affect readings that way. I'd go for the lowest Ohms.
« Reply #5 on: January 28, 2020, 08:55:54 pm »
I bought the meter from Amazon but would not trust Amazon for the fuses.
I'll just buy the one from Mouser that has the 2.9 ohm resistance.
Edit: Actually the Mouser part has 0.587 ohms resistance.
« Last Edit: January 28, 2020, 10:57:35 pm by rcbuck »
Offline jancumps
  • New Low
« Reply #6 on: January 28, 2020, 08:59:22 pm »
they are for sale on the EEVblog shop: https://www.eevblog.com/product/multimeter-fuse-pack/
Online J-R
« Reply #7 on: January 31, 2020, 05:59:10 am »
What I've got:
BM235 - SIBA 400mA 1000V: 1.33 Ohms
121GW - ASTM 400mA 600V: 1.89 Ohms
ASTM 400mA 1000V fuse pack from Dave's shop:
1.80
1.89
1.79
1.74
1.79
Total resistance on my BM235 is near zero in the 10A range, 2.35 Ohms in the mA range and about 100 Ohms in the uA range.
« Last Edit: January 31, 2020, 06:26:40 am by J-R »
