Author Topic: Do Rigol scopes autosense probes (1X, 10X, etc.?)  (Read 938 times)
Offline Dave92F1Topic starter
    • Nerdfever
« on: September 08, 2023, 06:58:07 pm »
Do any Rigol oscilloscopes auto-sense probes (mainly 1X vs 10X)?
My Rigol DS2072A doesn't do that, and I often forget to change the setting manually (and then get confused why the voltages seem 10x higher than I expect).
I'd consider upgrading my scope if there were a model that had auto-sensing. Preferably Rigol (since I'm used to their UI and have learned to trust the scope).
Offline wasedadoc
Re: Do Rigol scopes autosense probes (1X, 10X, etc.?)
« Reply #1 on: September 08, 2023, 07:00:23 pm »
Yes.
A look at the photos of their 'scopes will usually show which do and which do not.
« Last Edit: September 08, 2023, 07:02:46 pm by wasedadoc »
    • Nerdfever
« Reply #2 on: September 08, 2023, 07:02:23 pm »
Which ones? As I said my DS2000 doesn't.
MSO5000?
Where would this be mentioned on Rigol's website for each product?
Offline RoGeorge
« Reply #3 on: September 08, 2023, 07:04:08 pm »
Not all of them.  For example, rigol DS1054z doesn't have additional contacts other than the BNC connector, and can not detect the probe settings or type.  More expensive Rigol models can.
    • Nerdfever
« Reply #4 on: September 08, 2023, 07:11:11 pm »
How can I tell which ones?
Offline tautech
« Reply #5 on: September 08, 2023, 07:12:40 pm »
Gold ring around the BNC for the probe autosense pin to contact.
The following users thanked this post: Dave92F1
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #6 on: September 08, 2023, 07:16:48 pm »
Contacts around the BNC like this MSO8204.
Offline Fungus
« Reply #7 on: September 08, 2023, 08:23:15 pm »
Just look them and ask, "Does the BNC connector look like this?"
Offline bdunham7
« Reply #8 on: September 08, 2023, 08:24:57 pm »
Do note that even if your scope has the sensing rings, you still need specific probes with the sensing probe and resistor.  And switchable 1X/10X probes typically won't have that, with the exception of one Probe Master model.  Also, the scope may not sense all probes, my Siglent SDS2354X only correctly senses 1X and 10X, which is annoying when you have 100X probes as well.
