When it comes with the same sheet of paper it is as useful as the "old" one..
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
And as long as they would use the same reference IC nothing great will change, maybe the stability but this you can check with a period calibration, regardless if new or old version.
do you really benefit from spending more money on calibration?
When I want to know if it´s "true", it should be worth the money.
My skepticism started when I realized that the components on the L/C board are not high accuracy types, but only those that were measured with their LCR meters.
Then most of the values are rounded.
It may be that I am "damaged" by my profession in this respect, but if it is advertised that it should be a device for the calibration of other devices, then it should also be documented extensively.
