As I only got one response for formal Alpha testing, I'll skip all the formalities and just drop the package in here for anyone who would like to give me some feedback
To install an .apk NOT from Google play, you need to go into Settings>Security then check "Unknown Sources".
Then get the file onto the device however you want, and open it. You might find it easiest to unzip it on a normal PC and email it to yourself, then just open it from the email.
If you don't currently have a file manager, I'd recommend ASTRO file manager, it's pretty good.
You need to pair with your BT device prior to opening the app through the BT settings, otherwise you won't see it.
When you uninstall the app, it will remove any preferences with the app, however it won't touch any data you've saved.
Note: This is a first Alpha version. It will look best on a 7" tablet, and OK on a 10", however I know it looks fairly crap on a phone...
At this stage I'm really interested in what features you'd like to see. I know it'll have some minor bugs (but nothing should be too bad.)Devices supported in this release:
-Agilent U12xx with BT adapter (I'd like to know if you've got something other than a U1241, and whether it works or not)
-Escort 3146A
-Generic serial meter, this can be anything that puts out readings as a serial stream with the following format:
ASCII reading + <LF> (Insensitive to what combination of LF and CR, as long as a LF is present, i.e. 0x0A)
e.g.
-1.245E-03 + <LF><CR>
