Author Topic: Joy-IT PSG-9080 firmware failure  (Read 1495 times)
Offline misuroTopic starter
« on: April 03, 2022, 11:11:25 pm »
Hi all,
I hope I can get help here,
PSG-9080
               I acquired brand new signal generator, from local shop representative of JOY-IT.
     Honestly first shipment was a disaster, I had to send it back due to display failure.
Second time came working fine after changing the supply power cable.
So, I have installed software for PSG-9080, play a little with settings and in my great wisdom decided to
update firmware since was old
         Followed all instructions, firmware confirmed OK on display of the unit and, after touching any key as I was advised
on screen, there was my surprise, totally bricked machine, power button lite blue and nothing else, display dead
Power cord on and off, no change..still dead.
Any solutions here?
Thanks in advance.
Offline Junce
  • Country: cn
  • Hello everyone!
Re: Joy-IT PSG-9080 firmware failure
« Reply #1 on: October 14, 2022, 01:37:59 am »
5.The black screen caused by the firmware upgrade cannot enter the main interface or is always in the boot interface solution
a.Cause
Flashing different versions of the firmware to different versions of the machine will cause problems such as program confusion and black screen.
b.Avoid flashing the wrong program
Before flashing the firmware program, you can consult the after-sales customer service to see if the product has the latest firmware program, and consider whether it needs a firmware upgrade. Be careful not to download firmware programs on non-official websites and other platforms for flashing.
c.Method of liberation
When there is a problem, you can flash back the firmware of the corresponding version of the instrument; if you cannot identify the version of the instrument, you can contact the after-sales customer service and provide the serial number of the product and which version of the firmware was flashed. The machine and the corresponding version of the firmware, and then upgrade the firmware.
d.Different versions of firmware download links
PSG9000 series firmware upgrade compressed package download link 1:
http://68.168.132.244/PSG9000/Firmware_upgrade_version_1.rar
PSG9000 series firmware upgrade compressed package download link 2:
http://68.168.132.244/PSG9000/Firmware_upgrade_version_2.rar
PSG9000 series firmware upgrade compressed package download link 3:
http://68.168.132.244/PSG9000/Firmware_upgrade_version_3.rar
Note: [Firmware_upgrade_version_3.zip] is the latest instrument and the latest firmware version. [Firmware_upgrade_version_1.zip] and [Firmware_upgrade_version_2.zip]
Firmware corresponding to two different versions of the instrument respectively. Each version of the instrument corresponds to a different version of firmware, please do not brush or insert other firmware programs by mistake.
Offline yo4tnv
« Reply #2 on: December 03, 2022, 12:10:15 pm »
It happened to me as well..
On JT-PSG8090 i got recently and couldn`t find anything better to do than trying to upgrade firmware to the latest from joy-it website, next it went bricked, only blue power LED stays on.
Anyway, problem is solved, JT-PSG9080 is alive again !!
Here`s how:
1. Switch off ACmains button.
2. Keep pressing "8" on keypad and switch on ACmains button, while pushing pwrON(blue) for a second.
3. Release 8 on keypad, the device will display bootloader mode.
4. Press '1" to prepare uploading firmware
5. use above file no2 which our chinese friend kindly provided, http://68.168.132.244/PSG9000/Firmware_upgrade_version_2.rar to resurect your generator.
6. don`t upgrade firmware, this device isn`t broken, so don`t attempt to repair it :)
7. enjoy !
73 de YO4TNV !
« Last Edit: December 03, 2022, 01:19:19 pm by yo4tnv »
The following users thanked this post: fjalvingh
