Author Topic: DMM other than Flukes that chirp on diode/transistor test?  (Read 5523 times)
Offline jayjr1105Topic starter
« on: April 10, 2021, 01:01:01 pm »
Anyone know of any other meters that chirp/beep while testing a good diode?  Maybe small but I find this to be almost an essential feature.  Looking around the $100 mark.
Offline Wytnucls
Re: DMM other than Flukes that chirp on diode/transistor test?
« Reply #1 on: April 10, 2021, 02:23:48 pm »
Uni-t UT161E
Open circuit voltage: About 3V
For normal diodes, the buzzer will beep once.
For short circuit, the buzzer will beep for a long time.
https://www.batronix.com/shop/multimeter/UNI-T-UT161E.html
« Reply #3 on: April 10, 2021, 03:42:08 pm »
Uni-t UT161E
At first I thought you were crazy, I have a 61E and it doesn't do this.  Then I noticed you said 161E.  Thanks for the recommendation.  Do you think the new UT61B+ will support that as well?  It's just a 6000 count vs 22000
« Last Edit: April 10, 2021, 04:01:54 pm by jayjr1105 »
Offline Wytnucls
« Reply #5 on: April 10, 2021, 07:20:49 pm »
Uni-t UT161E
According to the manual, the 161B/D or 61B/D+ also have the feature.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #6 on: April 10, 2021, 09:42:33 pm »
Keysight U1273A and U1282A (most probably their brethren U1271A/1272A and U1281A do that as well)
Offline 2N3055
  • Country: hr
« Reply #7 on: April 10, 2021, 10:24:31 pm »
BM785/6/9 from Brymen
The following users thanked this post: paulbt
Offline joseph nicholas
  • Country: mx
« Reply #8 on: April 10, 2021, 10:53:38 pm »
My recommendation would be to ask the store and they will tell you its capabilities.
Offline floobydust
« Reply #9 on: April 11, 2021, 12:15:10 am »
I haven't heard a diode-test beep feature for decades. What's a good diode? Vf varies between Schottky, Germanium, Silicon.
I see old Protek 506 using this criteria to display pass/fail, it's wrong for Schottky.
Offline rsjsouza
  • Eternally curious
« Reply #10 on: April 11, 2021, 12:36:18 am »
The Keysights do a short beep between 0.2V and 0.7V. Anything below 0.1V beeps continuously. Between 0.1 and 0.2V it does not produce a beep.
But I missed the OP's requirement of ~$100
« Reply #11 on: April 11, 2021, 04:19:46 pm »
Yes, pretty much this.  Just don't want to have to look up when testing for a good diode junction.  I have the Uni-T UT161B on order from Amazon.  If it doesn't have this feature I can easily return it but as someone said above, it appears the B supports this as well.
The following users thanked this post: rsjsouza
Offline BILLPOD
« Reply #12 on: April 12, 2021, 06:31:32 pm »
Good Morning JayJr.,  I'm a bit late to the dance, but I just now
checked my Uni-T UT890C and it beeps on diode test.  And only $22 on Amazon.   :-/O
« Reply #13 on: April 12, 2021, 07:20:52 pm »
Does the EEVblog BM235 have this feature?
Online Hydron
« Reply #14 on: April 14, 2021, 11:08:00 am »
I think I might have a go at making an app or script for my DMM6500 to do this, as I really like the Fluke method of a short beep for a diode, long for a short. The default diode test mode has adjustable threshold levels etc but has a continuous beep (of an oddly low frequency, but again I think this can be set in the app/script). Not <$100 though!
« Reply #15 on: April 14, 2021, 02:18:17 pm »
I ended up grabbing a Uni-T UT161B on Amazon on sale for $60 shipped.   It does in fact have a diode chirp when testing a good junction, and also has a continuous beep for shorted.  Continuity is fast but as @eevblog reported in his video of the UT161E+ the stupid visual LED for continuity is not tied to the buzzer but to the display.  (I agree Dave, big fail).
Offline Wytnucls
« Reply #16 on: April 14, 2021, 03:30:45 pm »
The old UT71A can also beep repetitively for a voltage, which falls below a threshold set by the user, in diode mode.
It still sells today for about 120 USD.
« Reply #17 on: April 16, 2021, 07:46:28 pm »
This UT161B is rather unimpressive in a lot of other aspects.  The diode chirp is exactly what I wanted but man the autoranging is so slow and the release lag of the continuity is so annoying.  Maybe I'm being too picky.  Otherwise on paper is such a good meter.  They even have a real beefy HRC fuse and much better input protection now.  I wonder with bi-directional communication built in now if it will be "hackable" or firmware upgrade-able.
Offline netsecrets00
  • Country: in
« Reply #18 on: May 18, 2021, 07:01:34 am »
Do we have list for DMM which beeps on diode mode ?
Online BeBuLamar
« Reply #19 on: May 18, 2021, 10:51:21 am »
And I thought all of them do!
Offline xavier60
« Reply #20 on: December 07, 2022, 02:18:14 am »
 Don't assume that all Fluke models have Diode Test beeps. My 18B+ doesn't. Annoying!
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline Anjum9694
  • Country: mv
« Reply #21 on: January 18, 2023, 07:58:36 am »
My UT61D+ has that feature. It can do long beep for shorts (0 volts) and short beep for as low as 150mV (enough for most schottky diodes).
Offline sonpul
  • Country: ua
« Reply #22 on: January 18, 2023, 01:27:55 pm »
Brymen BM879 has this feature. The function is called BeepLit™ diode test.
Perhaps you will find it in BM785, BM786.
Innovative BeepLit™ diode test – short-beep alert on forwarde voltages <0.85V, continuous Beep & Backlight effect for shorted diode
Offline alm
« Reply #23 on: January 18, 2023, 01:45:01 pm »
How innovative :-DD
User 2N3055 confirmed that it's present on the BN785 and 786 in addition to 789 almost two years ago before this topic was revived from the dead:
Offline rsjsouza
  • Eternally curious
« Reply #24 on: January 18, 2023, 02:43:56 pm »
Since this defunct thread was revamped...  ::)
The AstroAI M6K0R also issues a short beep from 0.0V to 1.0V. This meter is also known as the Kaiweets HT118A.
« Last Edit: January 18, 2023, 02:49:07 pm by rsjsouza »
The following users thanked this post: englishrupe01
