Author Topic: fluke 123 scope meter vs fluke 88 v multimeter suggestion  (Read 2611 times)
Offline abid0011Topic starter
  • Country: ae
« on: April 03, 2017, 10:19:39 am »
hello everyone.
just thinking to buy a fluke.
getting a used fluke 123 scope meter and 2 option is to buy a new fluke 88v millimeter.
the fluke 123 is old unit. but its a dual channel and scope.
does the fluke 123 still better than the 88v in terms of accuracy and functions.
need suggestion.
thank u.
Offline jeroen79
Re: fluke 123 scope meter vs fluke 88 v multimeter suggestion
« Reply #1 on: April 03, 2017, 02:53:00 pm »
need suggestion.
What do you want to use it for?
They're different instruments that have some functions in common.
What non-common functions do you need?
How did you come to these two options?
Why a scopemeter and why an automotive multimeter?
Specs:
http://www.fluke.com/fluke/nlnl/draagbare-oscilloscopen/fluke-120.htm?pid=55999
http://www.fluke.com/fluke/m3en/digital-multimeters/fluke-88v.htm?pid=56148
« Last Edit: April 03, 2017, 02:56:36 pm by jeroen79 »
The following users thanked this post: abid0011
  • Country: ae
« Reply #2 on: April 05, 2017, 09:55:36 am »
thank fro reply.
need to use this 123 scope meter for electrical purpose.
i am electrician work on cnc machines three phase  and motors.
work on cars etc.
and now start learning electronics as hobbyist.
need a meter which i can use as electrician  and also as electronic hobbyist.
got a used 123 scope meter.
if this meter can fulfill the above requirement  then no need to spend extra dollars on new.
thank u
Offline jeroen79
« Reply #3 on: April 05, 2017, 12:51:29 pm »
You already have the 123 scopemeter?
They could be be used but they're not that comparable.
What do you value?
The scope? Dual channels? Portability? Battery life? Builtin current measurement?
  • Country: ae
« Reply #4 on: April 05, 2017, 01:31:33 pm »
yes i already have the 123 scopmeter.
current measurements / portability /
Offline jeroen79
« Reply #5 on: April 05, 2017, 05:26:22 pm »
Then the 88V (or other regular multimeter) wins.
