Author Topic: Make or buy a temperature chamber in UK  (Read 3202 times)
Online trevwhiteTopic starter
« on: April 05, 2017, 07:45:48 am »
I need a temperature chamber that can do 0, 25C and 40C primarily but thinking if I am sourcing one it would be useful to extend the range but all depends on costs and size. I want something to regulate the temperature within a degree or so.
Anyone know of a good source for one of these? My feeling is it is not a product that is likely to be cheap. I am semi open to making one but I think it would take up too much time unless it was off the shelf stuff and maybe a day of work.
Thanks
Trev
Offline slurry
Re: Make or buy a temperature chamber in UK
« Reply #1 on: April 05, 2017, 08:40:48 am »
I would say go the DIY-route  :)
an old stainless steel fridge (restarant bench model variety) with a good lock is a great start and a put some money in a really good thermostat and tempcontroller setup with graph/logging and all that fancy stuff.
« Last Edit: April 05, 2017, 08:42:45 am by slurry »
Online nctnico
« Reply #2 on: April 05, 2017, 09:03:21 am »
There is a thread somewhere about converting a fridge into a temperature chamber. Found it: https://www.eevblog.com/forum/projects/diy-temperature-chamber/msg189860
The following users thanked this post: trevwhite
Offline nfmax
« Reply #3 on: April 05, 2017, 09:07:21 am »
You might convert a hotel mini-bar fridge. The cost should be trivial so long as you leave the contents behind!  ;)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: April 05, 2017, 09:13:03 am »
Thanks
Trev
How big a thing do you need to heat/cool ?
Day Job: Mostly LEDs
« Reply #5 on: April 05, 2017, 09:16:59 am »
Thanks for the responses.
Believe it or not, the primary requirement is to profile a LiFePo4 battery. To do this I need charge/discharge curves at 0C, 25C and 40C. The battery pack is only 5cm x 7cm x 2cm approx.
It would be nice to use it for board testing as well but my urgent requirement is for the battery profile job.
Offline vealmike
« Reply #6 on: April 05, 2017, 09:35:07 am »
Sounds like a job for a Peltier based coolbox.
« Reply #7 on: April 05, 2017, 09:46:40 am »
Yes - a peltier is totally viable for that size.
Offline 0xfede
« Reply #8 on: April 05, 2017, 10:17:53 am »
Peltier may be limited at 0C since you have to pump away the heat generated by the battery pack.
Can you make an example of discharge power?
Semel in anno licet insanire.
« Reply #9 on: April 05, 2017, 10:28:01 am »
In theory then I should be able to flip the polarity and enable the chamber to become a heater as well.
I do not think the battery itself is going to generate much heat so I think the diy project example seemed to suggest a temperature variation of maybe a degree or so. I think I could possibly calibrate this with a few dry runs.
I got a quote for a new chamber. The cheapest the company said they did was £7k. If I wanted to hire one it would be over £300 for a week and it would cost £187 delivery each way
I dont really want to mess around but from the information on the diy version it does look doable for this particular application.
Thanks everyone.
Trev
Online EEVblog
« Reply #10 on: April 05, 2017, 10:53:53 am »
It all depends upon how fast you want to ramp, and how much thermal mass and if it's dissipating significant power or not.
If slow is ok and a low powered product, then one of these is fine. But it won't go down to zero though.
« Reply #11 on: April 05, 2017, 10:55:59 am »
And it is also dependent on the ambient temperature. I would need to ensure that is stable when I set the thing up.
Slow would be find I think and I do not think there will be a lot of heat being generated from the battery during the testing.
« Reply #12 on: April 05, 2017, 11:12:26 am »
They actually sell the unit Dave tested here in the UK. 3C is pretty close. I wonder if I can get away with that!
