Author Topic: Siglent SDS2202X-E Roll Pk-Pk Bug?  (Read 955 times)
Offline 7thSenpaiTopic starter
« on: October 22, 2021, 10:27:29 pm »
I believe there is a bug in roll mode. Incorrect pk-pk measurement. If anyone with the same scope could varify..
Software Version 1.1.20 R3
FFPGA Version 2021-03-17
Conditions:
-Set to 50ms/div in roll mode
-Turn on pk-pk measurement
-Attach probe directly to power supply leaving the PS on
-Turn off scope.
-Turn on scope.
Seems to be affected in any roll mode (50ms/div or higher).
The measurement gets corrected if you turn off roll mode and turning back on.
Offline FrancisM
Re: Siglent SDS2202X-E Roll Pk-Pk Bug?
« Reply #1 on: October 23, 2021, 04:18:02 pm »
Hi 7thSenpai,
I'm with an SDS2352X-E of same software and FPGA version. I can confirm your findings about pk-pk measurement.
I must honestly admit it's the first time I use roll mode.
Francis
EDIT : I was too fast, seems my pk-pk value is the ripple wich maybe correct. I will test again with different voltage.
« Last Edit: October 23, 2021, 04:42:25 pm by FrancisM »
Offline FrancisM
« Reply #2 on: October 23, 2021, 05:06:45 pm »
Silly me, I was in Auto...   :palm:
Now I can really confirm !
« Reply #3 on: October 23, 2021, 05:54:50 pm »
Hello FrancisM,
Thank you. :)
Roll mode is really great love the feature! The bug is not serious but it gave me a slight heart attack looking at pk-pk values next morning.
