Author Topic: DIY Logic Analyzer Probe and Pods for Siglent (and LeCroy) scopes  (Read 73195 times)
Online Martin72
  • Testfield Technician
Re: DIY Logic Analyzer Probe and Pods for Siglent (and LeCroy) scopes
« Reply #225 on: August 12, 2023, 04:06:10 pm »
I wanted to fix the criticized positions first, because e.g. the front panel for the display is actually thinner than 0.8mm, so I had canceled everything.
Most parts were titled as OK.
(Kierkegaard)
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #226 on: February 01, 2024, 10:38:30 am »
Ok, my turn to make one of these.... Was any further development done to improve the performance or is as it stands good enough?
Did anyone ever take a look inside the Siglent probe?
I think I wouldn't mind having a go at modifying the design a little to match the Siglent with the way the probes attach, maybe using some 2.54mm rectangular header sockets.
« Reply #227 on: February 14, 2024, 03:52:26 am »
thanks a lot mate, that saved me a lot of trouble :-)
could have been cool if only they existed in correct color codes from 0 to 9
so i have to find a way to add a label, and if they are colored at the same time, i end up being confused
since i cant turn off my brains color decoder
Coloured LA/MSO channel tabs are being rolled out into all models that support MSO.
Then if you have coloured grabbers you might be able to match them up to the displayed tabs.  :)
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #228 on: February 14, 2024, 03:56:39 am »
Damnit, now I need to buy coloured grabbers...
Cheers Scott
« Reply #229 on: February 14, 2024, 04:04:20 am »
Link listed in my reply #13, long expired but the ePay listing description might help with a search.
Be sure to get the same style as OEM for best holding power.
Pics here:
https://www.eevblog.com/forum/testgear/diy-logic-analyzer-probe-and-pods-for-siglent-scopes/msg3496458/#msg3496458
Online KungFuJosh
  • TEAS is real.
« Reply #230 on: February 14, 2024, 04:33:29 am »
Are you referring to the E-Z Hook brand grabbers? I have them in my list: https://www.amazon.com/dp/B00R3R7IVC/
The following users thanked this post: tautech, TheDefpom
Offline TheDefpom
« Reply #231 on: February 14, 2024, 04:44:08 am »
Damn, those aren't cheap.... so I only got 2 pairs, you always need a spare.
Cheers Scott
« Reply #232 on: February 14, 2024, 06:10:55 am »
Perfect.  :-+
10 for $34 is well priced compared to the 10 lot of Tek grabbers a mate and I shared 20 yrs back, they were $5ea !
Online ebastler
« Reply #234 on: February 14, 2024, 06:50:03 am »
Online KungFuJosh
  • TEAS is real.
« Reply #235 on: February 14, 2024, 03:55:41 pm »
Another bit cheaper $21 set linked by ePay:
https://www.amazon.com/10PCS-Grabber-Jumper-Analyzer-Colors/dp/B083PRVPCR/ref=pd_vtp_h_pd_vtp_h_d_sccl_3/143-5889884-9612055?
I wouldn't trust those, especially not for the $10 savings. Some of the reviews mentioned the springs failing, or the grabbers being too soft metal to properly hold things.
Offline fredo_
« Reply #236 on: March 23, 2024, 06:33:02 pm »
Hi there,
Did anyone try the PCB Assembly service of JLCPCB for oz2cpu's design ?
Maybe someone as working BOM and CPL files ?
Offline fredo_
« Reply #237 on: April 20, 2024, 10:34:13 pm »
Well I'm proud to join the team of oz2cpu's design probe owners !  8)
I ended up ordering on JLCPCB with PCB assembly (single side). Boards arrived with half the 120R resistor soldered on the scope board (upper side) and the 86K6 and 120R soldered on the pod boards :
Soldering the missing 120R resistors and the 8p2 caps stacked on top of the 86K6 resistors was not a simple task for me, as it was my first time doing SMD stuff :scared:
I ended up doing it with solder paste and an hot-air gun (couldn't make a clean work on 0603 parts with a soldering iron...) :phew:
Everything works as expected (tested with an ESP32 board providing approx. 10Mhz output)  ;D :
« Last Edit: April 21, 2024, 10:30:20 am by fredo_ »
The following users thanked this post: ozkarah
Offline fredo_
« Reply #238 on: April 21, 2024, 10:34:35 am »
In case someone needs it, here are the BOM and pick and place files I used.
« Last Edit: April 21, 2024, 10:54:28 am by fredo_ »
The following users thanked this post: KungFuJosh, ozkarah
Offline mawyatt
« Reply #239 on: April 21, 2024, 02:32:44 pm »
If you go back and start searching with our inputs (like #72 or earlier then onto #138) we posted a version of Thomas's that included the ability to mimic the responses that the OEM Probe produces after modeling the probe with Rob's help. Our version worked well from the start with both twisted-pair ribbon cable and simple ribbon cable (didn't have any micro-coax) that we never followed up on optimizing the probe & cables.
This might be a good start if one wants to squeeze the most out of these probes.
Best,
~Wyatt Labs by Mike~
Offline rosenrot
  • Country: at
« Reply #240 on: June 14, 2024, 11:40:07 pm »
I've desided I want my own design of the PCB for RF1.37 (https://aliexpress.ru/item/1005003601266058.html) coaxial cables (1 ground pad for each input) :   and also make it more "equal". I think I'll try to have input-end 120 ohm resistor directly on the cable, without additional boards -- like here: https://community.element14.com/technologies/test-and-measurement/b/blog/posts/building-solderable-in-circuit-oscilloscope-probes
github repo with kicad project is here: https://github.com/aystarik/siglent-la
Any recommendations (signal quality/or anything else) getting one of these? Did we hear back if this design is working out?
I added some holes to hold a 3d printed enclosure later on.
« Last Edit: June 15, 2024, 12:41:18 am by rosenrot »
