Author Topic: Differential probe for offline PFC'd PSU  (Read 4346 times)
Offline FaringdonTopic starter
Re: Differential probe for offline PFC'd PSU
« Reply #25 on: July 14, 2022, 07:46:05 am »
Thanks yes i must admit those Telonic prices are  a lot better than some others.
'Perfection' is the enemy of 'perfectly satisfactory'
« Reply #26 on: August 10, 2022, 07:45:26 am »
Thanks for these great answers, and thanks jc101  i now have the micsig diff probe and its very good.
Of course, when i probe the current sense resistor (burden) of my PFC it is just full of pickup as these diff probes have each probe on separate lead......so i think i will still need to buy an isolation transformer so that i can use a  home-brew coaxial probe to look at it without so much common mode junk in the way.
Alternatively i woudl like to take the back off the scope, measure the DC output of the offline SMPS... disconnect it, then feed in a isolated DC supply and then i have a floating scope.
Its a Tenma 72-8225
Offline nctnico
« Reply #27 on: August 10, 2022, 09:29:23 am »
Its a Tenma 72-8225
Don't do that (unless you have a death wish). Buy a current probe instead!
The following users thanked this post: Faringdon
« Reply #28 on: August 11, 2022, 06:40:13 pm »
Thanks, the output current of the secondary  is just 100mA peak, so i dont think i can buy current probe to see that small?
Offline jc101
« Reply #29 on: August 11, 2022, 06:42:42 pm »
The current probes from Teleonic will see that, I was using them down to 15ma just fine. I can look the model number out tomorrow.
Offline nctnico
« Reply #30 on: August 11, 2022, 07:08:40 pm »
No problem at all. Alternatively you can use a current transformer in series with the current sense resistor. Wurth has several nice current transformers that work up to several MHz.
