Author Topic: Where can I buy these type of female banana ports? (Kikusui DC electronic load)  (Read 3121 times)
Offline Fusion916Topic starter
I bought this exact unit locally, but the front banana ports have issues. The left black screwon terminal is missing (the cap, the lug is there) and the right lug has something jammed in there. I want to replace them.
Is this a custom fabbed part or is there a standard lug and screw I can replace this with?
https://www.ebay.com/itm/KIKUSUI-PLZ-150W-Electronic-Load/370524317089?hash=item5644f865a1:g:nLUAAMXQwMdRE0XG
Offline JDubU
« Last Edit: March 14, 2018, 12:09:43 am by JDubU »
Offline ArcticGeek
I have this exact same load, and those banana posts are a much larger size than a standard banana post; that's because they need carry at least 30A which is what the load is rated for.  Standard banana posts are rated for only 15A or 20A, and are physically smaller is size than these larger capacity posts.  I don't know where you could find the 30A banana posts, I've never seen them in Digikey or Mouser or any other distributor.
Offline Stray Electron
   They sell 30A binding posts somewhere.  I've taken them off of surplus electronics and I just installed a bunch of them on five of my power supplies.  I'll look and see if I have more of them and if there's a name on them.
Offline Inverted18650
    • Test Gear Addicts
I have some 'crazy big posts' from an old inverter if you want them. Ill get a pic shortly for you.
Probably these ones you may consider:
Hirschmann PKI 110, rated at 35A, available in red and black. Found on ebay (no affiliation with seller).
https://www.ebay.com/itm/302605827352  <-- black
https://www.ebay.com/itm/302605836711  <-- red
Or, if you like more this version:
Hirschmann PKI 10A, rated at 35A, more colours and gold-plated ones available.
https://www.ebay.com/itm/222079300521
Example:
HTH,
Andreas
Online nctnico
Sure they exist (not the fake ones from Ebay):
http://uk.farnell.com/hirschmann-testmeasurement/931714101/socket-4mm-red-pk5-mls/dp/1176480
The big question however is whether these would fit in the same mounting holes.
Offline ArcticGeek
When I mentioned that I had never seen them at Digikey or Mouser, I meant that I had never seen any that are IDENTICAL to the posts used in the Kikusui load.  If you can get the other ones to fit in the same mounting hole without modifications that would work fine, but my guess is the mounting configuration would be different.
Online nctnico
My guess is that Kikusui used a 'local' Japanese brand which could be hard to find in the rest of the world.
Thanks guys I'll just get the 35A ones from digikey. It's not a big deal if they fit the chassis or not because I can just 3d print some spacer between the binding post and chassis to make it fit.
In case anyone cares, i bought https://www.digikey.com/product-detail/en/pomona-electronics/5018-2/501-1743-ND/737101 pairs of banana binding post and they fit perfectly as a direct replacement, here are pics of it installed on my unit:
So if you own this unit and need new binding post. These are good.
The following users thanked this post: edavid, theirishscion, Inverted18650
