I ordered one too from this seller, so I'll have to check it once I receive it, and report back. Hopefully it's not screwed, as that would probably explain the lower price... ![DMM :-DMM](https://www.eevblog.com/forum/Smileys/default/smiliey_dmm.gif)
Yes, please do report back on how your experience goes with the meter. I see that he only lists 2 left now on ebay. So that means he sold 3 of the original 5 listed since I bought mine.
I bought one of them, too. I'm also interested to see if the EF function works properly. (I'm assuming this is non-contact voltage detection?)
Received multimeter today. As I suspected, EF function is finicky, works OK if you hold it up to 120v wire, but waving your hand in front of the meter makes it go bonkers.
Other quick observations, autoranging is slow, as compered to other meters. Plastic quality / tilting bail cheap compared to Fluke 87, but that's expected. Nice large display. Selector switch could be a bit larger. All in all OK for price.
Also it is old stock from 2009, probably why they were somewhat cheaply priced.
