Author Topic: FLIR ONE Generation 2 Thermal Camera - The useful information thread  (Read 5291 times)
Offline FraserTopic starter
I am starting this new thread in order to provide a repository for FLIR ONE G2 information that may be useful to others. It will be a work in progress that I will add to as and when I have new information.
Please feel free to add your own useful information and comments. I am hopeful that this thread will prove a useful repository of knowledge.
I will be including a list of phones that are known to work with the F1G2 that will be added to when I receive reports from other users. The post will include comment on the apparent frame rate as this very much depends upon the capability of the host phones CPU etc.
Fraser
« Last Edit: October 10, 2015, 03:13:23 am by Fraser »
Offline encryptededdy
Re: FLIR ONE Generation 2 Thermal Camera - The useful information thread
« Reply #1 on: October 10, 2015, 03:06:59 am »
The FLIR Lepton 3 Core
Specifications
  • Uncooled Vanadium Oxide microbolometer
  • 160x120 active pixels
  • 12?m pixel size (FLIR's first and only microbolometer with this small of a pixel pitch)
  • 8.8Hz Refresh Rate, Exportable (unknown as to whether a 30Hz version exists like with the Lepton 2)
  • <50mK NETD, 20mk typical
  • Sensitive to LWIR from 8?m to 14?m
  • Built in 56 degree lens, f/1.1 aperture. Silicon doublet (two silicon lens elements). This is wider than Lepton 2's 51 degree lens. It is unknown as to whether a Narrow FOV lens will be available like for Lepton 2
  • Hyperfocal distance (since it's fixed focus) from 0.15m to infinity
  • Sun / overexposure safe
  • Video output over VoSPI or MIPI (MIPI is currently unsupported)
  • 12ms time constant
  • >99% working pixels, <1 dead pixels typical
  • Minimum and Max scene temperature 0°K to >400°K (-273°C to >125°C). Note this is not what the sensor is calibrated to measure correctly, only what it can image correctly.
  • Operating temp range -10°C to 65°C. Can work down to -20°C and up to 75°C with performance degredation
  • Mechanical Shock tolerance 1500g for 0.4ms
  • Vibration tolerance 4.3g RMS
Block Diagram
Pinout (view from back)
Two sockets compatible with Lepton 3 are Molex 1052028-1001 and Molex 105028-2031.
Spectral Response
Full Datasheets
Full Datasheet: http://media.wix.com/ugd/53cdb6_5191be73d1c943d78d2e1a095cb7f3b8.pdf
Lepton 2 vs Lepton 3 application note: http://media.wix.com/ugd/53cdb6_9b698564a2e84af6a955078615b3a9da.pdf
EDIT: The mu (?) symbol shows up as ? for me for some reason.
« Last Edit: October 10, 2015, 03:10:50 am by encryptededdy »
« Reply #2 on: October 10, 2015, 03:14:46 am »
Thanks encryptededdy :)
Offline thefamilyman
« Reply #3 on: October 10, 2015, 06:32:57 am »
Phone report:
Huawei P8
HiSilicon Kirin 930 8 core 2Ghz + 1.5Ghz
Mali-T628 MP4 GPU 1080*1920
Android 5.0.2
USB correct rotation: YES
APP runs fine but crashes after 7 seconds of video recording.
LIGHT function also causes APP to crash immediately.
Sometimes when APP firsts starts the image is just white with the MSX overlay and no colour gradient. I'll try take a screenshot next time.
Frame rate seems to be maximum theoretical of 9Hz.
Asus Nexus 7 (2013)
Qualcomm Snapdragon S4Pro 4 core 1.5Ghz
Adreno 320 GPU 1200*1920
Android 5.1.1
USB correct rotation: NO
APP runs flawlessly.
LIGHT function does nothing as there is no LED light on the device.
Because of the crong direction of the USB plug its kind of impractical to use except if I want to take funky selfies.
(I feel its very important to note the orientation of the USB socket on the phone or pad, its basically useless if its around the wrong way. I'll make up an extension cable so I can use it practically on my Nexus 7)
Offline arsenix
« Reply #4 on: October 19, 2015, 08:49:55 pm »
I did a tear down of the android device:
  http://hardtechlife.com/teardown-flir-one-for-android/
Direct link to google photos album with internal shots:
  https://goo.gl/photos/3ZaPUpjTTgqvJVdq8
LMK if other internal photos or closeups are desired I can add to the album.
« Reply #5 on: October 19, 2015, 09:26:07 pm »
Thanks for posting this information guys. I have been laid up sick since starting this thread and you have kindly covered two areas that I wanted to include. I invite others to add any information that they believe will be useful to others. I will add anything that I can contribute as and when able.
I will definitely be carrying out a side by side comparison with TESTO and NEC thermal cameras of the same resolution.
Fraser
Offline kaz911
« Reply #6 on: October 30, 2015, 07:17:24 pm »
Versions:
I have two iPhone F1G2
First one - reports hardware revision D
2nd one - reports hardware Revision G
2nd was bought from UK early September 2015 - first was bought from US earlier (about a month after release)
2nd one has a more " iPhone " designed outer box (White on White). 1st one is more Flir (Blue & White)
