Author Topic: New Sigrok/PulseView hardware support (Siglent SDS HD, Rigol DHO800...)  (Read 2590 times)
Online teddychn
Hi Fredo,
Thanks for sharing! I'm really excited to try your patched version.
With just CH1 acquisition, it works perfectly with memory depth equal to or less than 4Mpts. However, PulseView seems to wait forever with a data length of 10Mpts. My environment is a Windows 10 PC with an SDS2000X HD. Please take a look at the attachments to see if they have any information useful to this situation.
Appreciate it!
« Last Edit: July 21, 2024, 08:45:37 am by teddychn »
Offline Electro Fan
Hi folks !
Back from a beautiful journey in Scotland, I patched the installer to try and fix the read timing issues 8)
Link has been updated on the first post, and you can find it here as well : Windows (64bits) installer (zip password is 'sigrok').
@Frex / @dpenev could you please try this new version and see if it works any better for your scopes ?
This new version should also support all Siglent recent series, that is :
  • SDS 800X HD Series
  • SDS 1000X HD Series
  • SDS 2000X HD Series
  • SDS 3000X HD Series
  • SDS 5000X Series
  • SDS 6000L Series
  • SDS 6000A Series
  • SDS 6000 Pro Series
  • SDS 7000A Series
Best,
Frederic.
It is very impressive and valuable what you and the other contributors are doing with this project!
Thanks!
The following users thanked this post: egonotto, fredo_
Offline fredo_Topic starter
Thanks for the feedback @teddychn !
I'm almost done with Rigol DHO800/900 support (thanks to the work previously done by Diana Ellefson (OrionOth) and RemiNV here).
I'll switch back to Siglent SDS2000X HD to try and reproduce your problem right after that.
The following users thanked this post: egonotto, thm_w
~~~ Updated version with Rigol DHO 800/900 support ~~~
Hi folks !
Here is my attempt to add Rigol DHO 800/900 support to Sigrok/PulseView (link has been updated in first post too) : Windows (64bits) installer (zip password is 'sigrok').
Disclaimer :
- LA not tested since I only have a DHO 800 with an identity crisis  ;)
- Only works in TCP/IP mode
- Segmented mode only works if :
  1/ UltraAquire is manually activated on the scope (SCPI command to activate it does not seem to work)
  2/ Memory depth is set to 10Kpts or lower
Any feedback is welcome, especially from DHO 900 owners !
« Last Edit: Yesterday at 09:05:21 pm by fredo_ »
