I have a DG1022Z that I set up to produce phase-aligned sine signals at 60 Hz to simulate a power monitoring system. One waveform represents the voltage and the other the current.
I need to vary the amplitude and phase-relationships of the the signals to emulate various fault conditions and I don't really see this an an arbitrary waveform, more a timed or step-controlled change to the inputs in some sort of script.
Can someone please suggest / outline the best tools / approach to set this up for me?
I do have a LAN connection and will be using a PC running Windows 10 to control.
[EDIT] What I'm really trying to do is automate changes that I could make on the front panel as some kind of (ideally timed) steps e.g.
1. Running in a given state
2. Reduce amplitude of Ch2 to xxx and change start phase from yyy to zzz
3. Go back to normal (step 1 settings)
I'm reading the UltraSigma 'instructions' and it seems I could issue SCPI commands but I don't think UltraSigma allows me to created a sequenced list, am I right?
