Thanks, I took a deeper look today, and indeed, it was the two switching FETs that had gone totally short from gate to drain to source. I took them out and was told to order new ones and then I was moved off this job. This is a shame as I was going to analyse this SMPS more.....
This PSU contains a top board which has a linear regulator output stage on it. A bottom board which has the offline isolated SMPS on it. Also a front board (which I haven’t unscrewed yet) and presumably this contains the microporcessors etc. There is also a little Fan PSU board. This PSU must have given its assemblers a few nervous breakdowns. I had to take 30 dis-assembly photographs.
The offline SMPS bit is unusual for a 400V, 1A PSU..... It has no PFC stage. Instead there is the AC filter, and then the rectifier bridge…then a 330uF, 400v electrolytic capacitor. Then there is the transformer isolated SMPS. This appears to be a half bridge LLC converter (but possibly a series resonant converter of course) . It does comprise a current transformer. It does appear to have rail splitting film capacitors (each 200nF) which are supposed to protect LLC converters from startup transient damage etc. The Resonant capacitor appears to be 1 inch long 6.8nF film capacitor.
The 68uF electrolytic output capacitor of the LLC converter is only 400V rated…and 400V is a bit tight for a 400v output PSU…the unit has a linear regulator output stage, so presumably the LLC SMPS is outputting a little more than 400V when the unit is outputting 400V.
The LLC converter ( I believe it is that, after my short allotted time with it) looks very sparse on componentry. I cannot see a controller chip for it…….other than a IR21531S chip on a little daughter board which is a “self oscillating half bridge driver”...
IR21531S datasheet
https://www.infineon.com/dgdl/Infineon-IR21531-DataSheet-v01_00-EN.pdf?fileId=5546d462533600a4015355c8d26316b3This is a cause for some concern, since LLC converters have failure modes which really need either a custom microcontroller solution, or a custom LLC converter IC.
Please may I ask if anyone has a schematic for this PSU?. I believe its very common as its so cheap, and there is another post about it here on EEVBLOG (but doesn’t go into details about the SMPS bit or any failure modes) I am beginning to suspect that its not very robust at all.
