hello to all,
I have for some time my F G 4102 without any upgrade (fw 00.01.03),and I want to upgrade it at 160 MHz .
My 1st attempts have been made with rory’s instructions Reply #67 on: November 16, 2013, 05:44:44 PM but It’s too complicated for me( I’m lacking knowledge of linux).
The 2nd was with bandgap instructions on Reply #104 on: November 20, 2013, 06:40:38 PM ... I made several attempts and combinations as described , but nothing valuable came out.
( something is wrong / I’m wrong???)
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
1) Go to
http://www.compileonline.com/compile_c_online.php2) Replace the code in the left box with the code below.
3) Put your command line arguments in the text box at the bottom (in the form <current model> <new model> <current serial>)
4) Press "Compile and Execute" in the top left
5) Press "Download Files" in the top right (assuming everything executed properly)
6) The result tar.gz file will have the proper license.CEN file contained within it.
I don’t want to use 200MHz
Anyway, Could someone post some detailed instructions step by step on that, or could someone make any upgrade for me?
Thanks.
PS: I managed to h/k my msox2014a successfully .Thanks to the forum and the contributors
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
