This is my first time writing.
This is a question regarding a problem with RIGOL DG4062.
I bought a used DG4062. Firmware is 1.04. (I'd like to update this to 1.08 somehow, but I can't get it.)
I posted this because I wanted to know if the following problem can be improved by updating the firmware. RIGOL's official website doesn't seem to have a history of bug fixes, so it's impossible to determine whether this is a hardware failure or a software bug.
When testing, I found that for CH1, the output was largely discontinuous at output impedance settings other than High-Z (for example, 50 ohm). If you gradually increase the output from the minimum output (-56dBm), the output will be abnormally large in the 4 steps before the relay switches. When the relay switches, it returns to the continuous increasing state before the abnormal value. Also, in the High-Z output, the output is slightly discontinuous between 3.5mV-4.0mV and 80mV-110mV.
If it's a hardware failure, I'd like to try to repair it, but unfortunately I don't have a circuit diagram, so I think it will be quite difficult. If anyone has any clues, I would appreciate it if you could let me know.
