Hello folks. I think the upd file is corrupted (00.08.).I downloaded too, and no respond. You need a clean update, ask some one here on the forum, someone have it, if you need it. I have a soft ver. 00.01.06 thats worked for me.
Important note is the handling of the boot procedures in some DGs, IT matters how you power up your fg to read the stick!!!
Some tell to <let fg work normal, put usb stick in, let him recognize it, power down, press HELP button and power up,If went ok, you see the ramp button
flashing and after a while its stops and stay lit, and the flash go to other buttons (Waveform) and make the same procedure , and stop at USER button in the same way.> Thats the normal way. (sandisk cruser mikcro 2.0 gb formated full FAT32).It worked for me.
Next step:Download cengen.exe, put it on root directory (c:\cengen.exe) and let it there.
Open cmd.exe and type in c:\cengen.exe XXXXXX XXXXXX serial number and press enter. (Modify it accordingly)
You get a message: SUCCSESS: licence file saved to:licence.CEN, Next, make a search on your computer, you find it as the nearest in time or date,
that's your file.
Next step, make a copy of it and put it in a folder marking it as valid licence.CEN file. Copy it to your USB stick as licence.CEN.
Put it on your DG in and let it recognize it, Press Store button and select it at D, press Read, and it's popping up a message: invalid licence file.Too many errors.
Press again Store button and you got:Valid licence file or so. Go then to Utility to validate/verify the changes.
Hope it helps ...Thank's to the forum!!!
