Hello everybody !
First, I'm sorry for my english... I'm French and the school is so far...
I have two DG4062 (#3 is not mine) and I have working to obtain the last firmware (01.14) AND 200Mhz version.
By luck, I had three DG4000 to play with:
#1 DG4062 with "Keyboard version" (Bootloader) 06.01 and FW00.01.12 ("upgraded" in DG4102 model before upgrade FW00.01.12/Bootloarder 06.01)
#2 DG4062 with "Keyboard version" (Bootloader) 05.01 and FW00.01.06 (leave in DG4062 model)
#3 DG4062 (My father one) with "Keyboard version" (Bootloader) 06.02 and FW00.01.13
I will now explain how I have proceed...
First, I have unsolder the flash memory chipset S29GL128P90TFIR1 from the #1
- I have read the flash with a RT809H
- Write a blank flash chip with the content (I know, no modification at this state
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
I have use a S29GL128P11TFI020 (R&S dont have the exact ref. but the speed is not very important, just the time to transfer the content at each startup of the DG to RAMs module. (Difference is not perceptible)
- I have solder a TSOP56 socket in the DG at the flash place.
- Put the newly write flash in the socket, power ON and the DG work as before...no progress but desolder/cleaning/read/write process was valid !
I have start with #1 becaus I was aware about the process and if I make a mistake, I prefer to kill the flash with the bootloader 06.01 and make my second try to the #2 with knowledge of my eventual mistake...
After that, same thing with the #2 with success... Ouf... the big deal was over...
At this state, I had two DG4000 with socket in place of the flash and two .BIN. I can write flash with this .BIN and put inside each one.
When I put the #1 flash in #2, #2 work as #1, same serial, same version at all (Device model, serial, Soft. Vers., FPGA Vers. and Keyboard Version)
*For information, the Hardware Version is not in the flash (normal) it's hard Coded, 5 Zero Ohm resistor are inside and the version is binary coded: For Hard ver. 1.3 resistor are 01.011 (It' near the buzzer)
Ok... I know what you think...
"He write the #1 Flash with the #2 .BIN and he can use the licence key file to have DG4202 because he don't have the 06.01 bootloader limit..."Yes, I can...but it's not sufficient. I don't want to have two DG4202 with old firmware...
For memory, the Goal was two DG4202 with latest firmware (01.14 at this time)
But with socket and the hability to write directly the flash with the content I want, I can make lot of test.
If I brick the DG... just unpluged the flash, program it again with a working content and then test again...
I can make tests without stress...and it's that I did.
Rest of process :
- I have write the #2 flash content (FW 00.01.08 Keyboard Ver. 05.01) to a new flash and plug it inside one DG4000
- Create licence file with Cybernet method. Model DG4062 --> DG4202 without change the serial
- Upgrade Bootloader to 06.01 (Rigol process)
- Upgrade to FW 00.01.12 (DG4202 model is preserved)
- Upgrade to FW 00.01.14 (DG4202 model is preserved)
I don't know why the DG4202 model is preserved when I come from FW 00.01.08 Bootloader 05.01 --> FW 00.01.12 and 00.01.14 Bootloader 06.01...
The case of the #3 : I have unsolder the flash but the socket soldering was a failure...
Finally, I have read the flash content to have the .BIN and I have solder directly a new flash with alreday DG4202 model FW V00.01.12 Bootloader 06.01 and after I have upgrade to FW 00.01.14 (keeping model DG4202 as for #1 and #2)
But the difference for the #3 is the Keyboard Version... When I have start to work with this DG4062, the Keyboard Version was
06.02 For memory, when I put a flash (.BIN) coming from #1 or #2 to #1 or #2 all version except Hardware ver. follow (Device model, serial, Soft. Vers., FPGA Vers. and
Keyboard Version)
When I put a flash with an older version of the Keyboard, the Keyboard version is downgraded.
For the #3, the Keyboard Version DON'T change, all the rest change (Device model, serial, Soft. Vers., FPGA Vers.)
My conclusion, in the #3, the Keyboard version is elsewhere... (I have search at the keyboard PCB in #1 and #2 and the LATTICE chipset LCMX0256C don't inform me, no ROM in this version but...)
I don't understand this point.
At this time I have following FW (Rigol update files) :
- 00.01.04.00.02
- 00.01.06.00.02
- 00.01.07.00.03
- 00.01.08.00.02
- 00.01.12.00.02
- 00.01.14.00.01
In the #3, the firmware was 00.13.00.XX but I don't have original files from Rigol. If somebody have some other Firmware, I'm interested (All versions I don't have already).
Here, I don't have explain all steps of my work, it's to long for one message, if somebody is intersted, I will continu to explain other action.
First Goal : Have two DG4062 upgraded in DG4202 with last FW and be able to search without risk --> Achieved
Next Goal : Flash from file or from JTAG (I don't know how to flash the flash memory from JTAG port (or other present at the mother board), If someone can explain to me, I will be happy)
Next Next Goal : Understand where is the Keyboard version in the #3, extract and flash if possible in #1 and #2
I hope to restart this old subject
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
