Bandwidth and slew rate is not that far above max frequency of 25MHz so don't expect miracles with anything other than sines up to max frequency. The fast edges of squares require much more bandwidth than this due to Fourier. For a 25MHz square, the total system bandwidth needs to be 175MHz or greater to get good edges (7th harmonic). Better to get a pulse generator if you want fast edges.
