Author Topic: Design a New Precision LCR Tweezers with Much Lower Cost 【Shannon Tweezers ST42】  (Read 145619 times)
Offline ShannonTopic starter
  • Country: hk
Re: Design a New Precision LCR Tweezers with Much Lower Cost(Video Attached)
« Reply #625 on: February 20, 2024, 04:22:19 pm »
Now we have to wait for firmware  ;)
No need to wait any longer, just update your tweezers right now. >:D
You can see that the negative pulse before the positive pulse has been cancelled.
The voltages from the signal to the positive and negative power rails are asymmetrical.
So the absolute positive and negative voltage is not same, which is normal and does not affect the functionality.
Nature and Nature's laws lay hid in night:
God said, Let Newton be! and all was light.
  • Country: hk
« Reply #626 on: February 20, 2024, 04:48:24 pm »
1) Shannon told me that the Hardware is 100kHz compatible, so hope to have this.
I said "It is possible", not "compatible" :palm:
The reason is that we also had plans for 100kHz tweezers before, but that was another design.
We have not verified the feasibility of ST42 supporting 100kHz.
It is only a theoretical possibility, let alone guaranteed accuracy.
2) Rdc: add a "quick" Delta/REL function with Joystick Up or Down
           (as these button doesn't do anything on Rdc mode).
There is no plan. If many friends think there is a need for this use, we will consider it.  :popcorn:
3) Rdc: in general calibration menu, add Open and Short calibration.
The contact error causes the offset of each measurement to be tens of milliohms, and the measurement accuracy of Rdc is good enough, so there is no need for calibration.
4) Diode mode:
   - Short beep to tell good diode value (Voltage between 0.45V and 0.8V)
   - Double short beep for schottky (Voltage between 0.1V and 0.45V)
   - Continuous beep for dead diode (when shorted)
We will consider adding a diode to give a beep.
It does not distinguish between Schottky, ordinary diodes, and other situations (short, both forward and reverse conduction voltage drops).
Users can try to distinguish Schottky and ordinary diodes by looking at the voltage values on the screen.
The voltage boundary between them is not so obvious. We must ensure that the output information is accurate.
5) Change icon in Auto-Mode, as we don't really know when we are in AutoLCR mode or not.
    (the Inverted "A" is showed breafly at the beginning, and then replaced by the mesured value)
    I have attached moded photo of screen with my simple idea for that:
    Inverted letter in AutoLCR mode, compared to normal letter in manual mode).
We will consider adding it.
My habit is to short-circuit the tip of the tweezers when in doubt. If it changes from capacitor to resistor, then it is Auto LCR.
6) Shutdown on battery-charging at 100% if it is possible, to save Oled display.
No plan, the life of OLED is long enough, and the lifespan degradation caused by the screen being bright during this charging time can be ignored for the time being.
7) Modify Diode test signal (From Shannon: "change the voltage first and then enable the output")
a) Strange behaviour of Battery charging
We are considering how to solve this problem. ;)
Offline ceut
« Reply #627 on: February 20, 2024, 05:08:33 pm »
It is the first time I try updating my ST42, but I have an error message  :-[
The same error on 2 computers  ???
Do you have an idea about this error ?
Thank you  :)
Online KungFuJosh
  • TEAS is real.
« Reply #628 on: February 20, 2024, 05:13:54 pm »
Is there a new firmware release? Your website still says 2023/5.
  • Country: hk
« Reply #629 on: February 20, 2024, 05:16:37 pm »
Just upload the new firmware a momenta ago, the website information has not been update.
And there are some other modification is under processing. ;)
  • Country: hk
« Reply #630 on: February 20, 2024, 05:18:54 pm »
Thank you  :)
when you unplug the USB cable, the COM8 port in the device management will disappear?
Offline ceut
« Reply #631 on: February 20, 2024, 05:33:52 pm »
Yes, I have just checked it and it is the ST42.
I have upgraded the driver to 3.7.2022.1 version (was on 3.4.2019 on my previous screenshot):
same error (I'm on com4 on this computer)  :(
Will try back home on other computer.
Online KungFuJosh
  • TEAS is real.
« Reply #632 on: February 20, 2024, 05:52:32 pm »
Ohhh, fun. 😉😉
Offline ceut
« Reply #633 on: February 20, 2024, 06:36:56 pm »
I have tried on 3 computers at home (+2 at work): no luck  :-[
Same error message on all as see on photo.
I have also a Windows 7 computer, but the fw_update-win.exe shows an error "api-ms-win-core-path-l1-1-0.dll"
Tomorrow at work, I will install a Windows11 from scratch on a test computer, and will try the update again...
My Bootloader version is 1.3.1 and original FW 1.5.3.
« Last Edit: February 20, 2024, 07:29:39 pm by ceut »
« Reply #634 on: February 20, 2024, 07:38:19 pm »
Feel your pain, been there done that and earned the shirt and still had to take mine to Defpom for him to update.  :rant:
Start reading here:
https://www.eevblog.com/forum/testgear/design-a-new-precision-lcr-tweezers/msg4945249/#msg4945249
Offline ceut
« Reply #635 on: February 20, 2024, 08:17:29 pm »
Start reading here:
Thank you Tautech for trying helping me  :)
I have read your attempts to update it, no luck for you also  :-[
So I have tried again with the latest 3.8 drivers from here: https://wch-ic.com/search?q=CH340&t=downloads
No luck too. The ST42 is showing well on the peripheral manager with a visible COM Port, but the "fw_update-win.exe" has always this message on all my computers "INFO:root:cmd send time-out, no reply" then fails.
If I try with an existing COM Port which is not the ST42 in Bootloader, I have a "serial port open" error, so not the same error as the ST42.
Also, I use Arduino sometimes, and I have not a single problem with loading sketches on them (same CH340 driver but not same COM port number).
And I have cleaned all old drivers version with Rapr.exe wich I use a lot for fixing computers.
It is like the Bootloader is locked  ???
To be continued...
Edit: tried on Ubuntu live, same error message as windows, it is really difficult to update the ST42  :-[
« Last Edit: February 20, 2024, 08:56:24 pm by ceut »
  • Country: hk
« Reply #636 on: February 21, 2024, 01:01:07 am »
Start reading here:
Thank you all for your feedback.
I can't stand these upgrading problems anymore >:(, and decided to update the download instructions on the web page recently.
At least the following plans are in place:
1. Record more detailed and high resolution operation videos (covering all operating systems as much as possible)
2. Provide graphic descriptions (covering all operating systems as much as possible)
3. Collect and organize common problems and provide solutions
The following users thanked this post: eliocor, thm_w, tautech, SilverSolder, Grandchuck, KungFuJosh
Offline ceut
« Reply #637 on: February 22, 2024, 04:52:36 pm »
Just a follow up for my update problem.
=>After many hours spent, with the help of @Shannon  :) , my problem is a hardware problem.
After reading the CH340E datasheet, the 1rst thing I have done is soldering a Led on pin 6 ("TNOW") which is not used inside, and is a pin to see is there is transmission activity.
After that, I have seen the Led blinking: so no problem with computer or com port or anything else.
So I have investigated more, and have desoldered some compenents to find the culprit.
=>The USB/RS232 transceiver chip (the CH340E) is damaged (shorted) only in one pin: the pin 9 which is the RX (connected to the TX pin of the main chip). The mainchip replies but the CH340E, with its RX pin shorted, doesn't send anything to the USB port.
Hope I'm the only unlucky guy who has this hardware problem  :-[
Here are some photos I have made if interested.
Shannon will send me the chip
The following users thanked this post: thm_w, Shannon
  • Country: hk
« Reply #638 on: February 23, 2024, 06:24:21 am »
I am very grateful to ceut for his efforts. I am amazed by his proficient use of instruments and soldering skills.
What is even more valuable is his ability to analyze problems.
Add another point:
Very strange, this is the first time I encounter such a problem.
Because the RX of the CH340E is a pin on the PCB, it is not exposed to places where humans and static electricity can come into contact like the D+/- of USB. here is the datasheet link:https://www.mpja.com/download/35227cpdata.pdf
And we have no other flashing method. The st42 must be flashed to the latest software version using this USB port before leaving the factory, which means that it has worked normally.
If the power pin or D+/- is broken, it can be understood that the non-standard typeC interface may provide excessive voltage, or the D+/- pin may be damaged by static electricity.
Thanks again ceut for your support and patience.
Traditional rules, new suggestion/issue, new gifts.
« Last Edit: February 23, 2024, 06:27:01 am by Shannon »
The following users thanked this post: ceut
Offline ceut
« Reply #639 on: February 23, 2024, 01:46:54 pm »
Thank you very much for your message and support :)  :-+
Add another point:
That's also what I don't understand :-\
I have only charged twice since I receive it, with great quality USB charger and Cable from Ugreen and always with my UM34 USB Meter.
Also it is the first time I plug it on computer
Thank you  :-+
The following users thanked this post: Shannon
Offline SilverSolder
« Reply #640 on: March 04, 2024, 11:26:53 pm »
Is there a link to the current firmware version somewhere?
I can only find version 2023-5-10 ...
Online thm_w
  • Non-expert
« Reply #641 on: March 05, 2024, 01:56:20 am »
Does the updater tool not work?
Offline watchmaker
  • Self Study in EE
    • Precision Timepiece Restoration and Service
« Reply #642 on: March 07, 2024, 06:59:53 pm »
Shannon,
Just to let you know the windows exe updater tool works fie on my windows 11 computer.  Thanks.  Very simple.
Regards,
Dewey
Offline Veteran68
« Reply #643 on: March 08, 2024, 12:37:19 am »
I intended to but forgot to come back here and report that the updater worked fine on Windows 11 for me as well.
« Reply #644 on: March 08, 2024, 02:14:01 pm »
Where are you downloading the latest firmware and updater from?
I can't find it on https://shannontweezers.top
I can't find it on https://github.com/shannontweezers/shannontweezers.github.io/
I must be overlooking something obvious...
[Edit:  As usual, posting a question makes you see the obvious within about 100 milliseconds.  In this case, (1) an earlier post by Shannon saying that the web site hasn't been updated to talk about the latest version yet, so looking for a recent date is pointless. and (2) the tool downloads the latest firmware over the Internet, irrespective of what the release date of the tool itself is.]
« Last Edit: March 08, 2024, 02:23:03 pm by SilverSolder »
  • Country: hk
« Reply #645 on: March 10, 2024, 01:33:39 pm »
Yes, the second one is the right answer, we try to make the updates more simple, which is independent to the firmware version
Just update it by the firmware update exe ;)
Offline ceut
« Reply #646 on: March 14, 2024, 09:35:59 pm »
Last follow up/fix for my ST42 (I have informed Shannon about that   :-+ ).
I have taken a CH340E from a BTE17-06B board, and have put it back on my ST42: the update now works great  :-+
The updater is fast and my ST42 is alive again  :)
It was really difficult to do all this, and even to put all back with the battery and closing the case (I have also damaged a litte the bottom part of my ST42 ).
Hope my ST42 will work great for a long time now..
Now I can play with it again+check what changes inside, and update my proposal from here https://www.eevblog.com/forum/testgear/design-a-new-precision-lcr-tweezers/msg5345456/#msg5345456
and reply from Shannon
 8)
Online KungFuJosh
  • TEAS is real.
« Reply #647 on: March 15, 2024, 12:32:09 am »
Nice work!
Offline battlecoder
  • Country: cl
    • A BIT of Mystery
« Reply #648 on: March 15, 2024, 05:52:41 pm »
Well I went into this thread once again, this time because I was having problems updating my ST42 so it's funny that you say "hope you are the only unlucky guy who has this problem" because I'd like to introduce myself: Hi, I'm another unlucky guy, it seems :/ I'm getting exactly the same error, and I'm not really happy to hear it's a hardware problem. Is replacing the chip the only solution?
EDIT2: I would like to add that I remember updating the firmware when I was having the screen glitches (which I also reported here). And I don't remember the process giving me errors that time. Maybe this is not necessarily a hardware problem (in my unit at least) but rather that the sofware gives the same error under different conditions (including faulty hardware).
EDIT3: Ok, "solved" the issue and I'd like to keep a record here despite being a very silly mistake from my part. Apparently the intimidating error shown by the updater is the same in case of any problem communicating with the device. In my case it was either a driver issue or a cable issue, because changing the cable and usb port I got it to work.
BUT I also got the same error during one attempt in which I didn't enter into bootloader mode correctly. The COM port appeared on my computer but it wasn't in *actual* bootloader mode.
So I'd like to leave this post here as a warning for others: Even if you get the same error, it does not mean it's a hardware error. As obvious as it is now, the firmware updater will give the same error in any case in which the device is not responding back.
« Last Edit: March 15, 2024, 06:17:23 pm by battlecoder »
The following users thanked this post: ceut, thm_w, KungFuJosh, Shannon
Offline shapirus
  • Country: ua
« Reply #649 on: March 27, 2024, 07:38:53 pm »
@Shannon how difficult do you think it would be to implement a special electrolytic capacitor testing mode? Electrolytic caps are polarized, and thus the correct way to test them is (I think) to bias the test signal to the Vpp/2 level, so that it always stays above zero instead of the standard AC signal of +/- Vpp/2.
I'm not sure what difference it will make though, but it just seems to me that applying a reverse polarity voltage to electrolytic caps, even if low and only for a half period, isn't quite right -- might be from the cap damage or the measurement precision perspective, or both. There are some LCR meters that implement this biased signal mode, e.g. East Tester ET432/433. I'm not able to find any good info on this topic, only vague suggestions that it's "better" to test the electrolytics with a positively biased signal, and it gives better precision.
