I have sent a PM to Shannon for this strange behaviour.
Also, I give you the list of all proposal I have made by PM to Shannon for firmware improvement:
(but I don't know if these ideas will be implanted
![Embarrassed :-[](https://www.eevblog.com/forum/Smileys/default/embarrassed.gif)
1) Shannon told me that the Hardware is 100kHz compatible, so hope to have this.
2) Rdc: add a "quick" Delta/REL function with Joystick Up or Down
(as these button doesn't do anything on Rdc mode).
3) Rdc: in general calibration menu, add Open and Short calibration.
4) Diode mode:
- Short beep to tell good diode value (Voltage between 0.45V and 0.8V)
- Double short beep for schottky (Voltage between 0.1V and 0.45V)
- Continuous beep for dead diode (when shorted)
5) Change icon in Auto-Mode, as we don't really know when we are in AutoLCR mode or not.
(the Inverted "A" is showed breafly at the beginning, and then replaced by the mesured value)
I have attached moded photo of screen with my simple idea for that:
Inverted letter in AutoLCR mode, compared to normal letter in manual mode).
6) Shutdown on battery-charging at 100% if it is possible, to save Oled display.
7) Modify Diode test signal (From Shannon:
"change the voltage first and then enable the output")
List of "bugs" (?) :
a) Strange behaviour of Battery charging
b) Diode test signalThanks
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
