I guess, you've seen that the pretty model ST5S/LCR Pro1 is 2 or 3 times expensive. ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Well, I don't want to talk much about those product's shortcomings, they are more like DMM, here is a test and analysis post, you can get more details.
Have you ever seen an LCR Tweezers that could achieve 0.01% noise performance at that speed?
And look at the test image, we used 0.01% 2ppm precision resistors for the DUT.
We will post more details about the performance and structure design, it used as real precision tweezers, very easy to hold 0402 SMD components.
It is much more convenient to use than a stationary LCR meter, it could support SMD(independent or soldered on PCB) and through-hole components at the same time.
We have great confidence in it, you'll want to have a try ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
The DT71 looks much more elegant and comfortable, the ST5S is unsightly. To use these tools as high-precision seems to me unwise. You can easily calibrate a demo sample and lose accuracy in mass production. If you ensure accuracy in mass production, it will be good. But we don't know that yet. ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I didn't buy a DT71 for $50 and I won't buy yours for $100, it's expensive and more convenient for me to use a stationary device.
It is often very inconvenient to look at the tweezer readings when checking on the board due to the forced position of the tweezers. However, I suggest that you, as a friend function that will cure this deficiency: automatic locking readings. It works like this: if the measured value is stored for more than, for example, 2 seconds, issue a beep and record the readings so that you can turn the tweezers and look at the screen. Of course, the time and on/off of this function must be added to the settings. ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
What stationary device do you use?
I like the idea of the reading becoming "sticky" on the display, so you can review it. Why not keep the previous reading until the user takes a new measurement...
Hi SilverSolder,
we have implemented hold function.
if hold mode was enabled, when the tips of tweezers leave the DUT, the test result would keep display.
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
The reason is that it's not easy to decide when the tips are leaving the DUT
For example, assume the DUT is a precision resistor, the test value is stable before we try to release the tips, and then we loosen the arms of tweezers, contact states are changing, milliohm contact resistance is introduced, but the test is still running, and a new test result is displayed on the screen which has some uncertainty.
So hold function is better to be an optional mode when you can accept some uncertain, even though these uncertainties are usually small
There is a way to hold the precision result is we ask this tweezers "HOLD" the value during stable measurement, and tweezers stop the measurement and keep the stable value until next measurement.
