Stupid question of the day - I just received my ST42 tweezers and while it seems intelligently laid out, I’ve never used an LCR meter before…. The included documentation only shows the menu structure and doesn’t include any information on how to actually use them or why choose certain options such as frequency. Is there a good reference somewhere that explains how to best use an LCR meter like these?
Also, is there a suggested calibration routine using the open/short calibration in addition to the autocal option?
Autocal is often good enough by itself, but at least once in a while, or if something seems off, you should do the full open/short cal.
Frequency range depends on what you're measuring. Some things won't work, or not be as accurate in the wrong range. The attached image shows the ranges and relative accuracy for my ST2832. You can use that as a guideline. But I'd probably leave it in 1k most of the time, and adjust when needed. IIRC pressing the joystick up shifts through frequencies (I'm left-handed, it might be different from your position).
