Lightages, no temperature probe included, I tried a K-type to DMM adaptor from another multimeter and it seemed to work fine so the original adapter is nothing special, you get 0.1 degree resolution on temperature, nice.
Mirkot, I looked at the probes again and they are not the same as the ones from the Hioki multimeter, the shroud is not detachable, I tried really hard to pull or pry them of but they would not budge, on closer inspection the tiny seam from the plastic moulding tool aligns perfectly on the shroud and the rest of the probe on both probes so I have to conclude they are one piece.
I thought there might be a demand for pictures of the inside, so here are some more pictures:
Pictures
1: Overview of the board, no main chip here! Wires from the battery holder permanently attached.
2: Lower part of board, input protection and lots of it, insulation slots, seems like a serious effort.
3: Upper part of board, 14pin SOIC marked ES636 is a copy of AD636 RMS converter from Cyrustek.
4: Other side of board still no main chip visible
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
but a little bit more of the input protection. I found the main chip under the display, no surprise there, unfortunately it looks like the display is held in place by four plastic legs on the display that has a friction fit in the holes in the PCB so if I pry the display off the board I am not sure there will be enough friction left the second time the display is mounted to hold it securely, it's a zebra strip between the display and PCB. I have to confess I chickened out here and left the display in place, sorry.
