Author Topic: DSO Recommendation  (Read 2484 times)
Offline 9s12Topic starter
DSO Recommendation
« on: December 07, 2023, 03:45:19 pm »
I repair automotive control units as a hobby, and I am looking to upgrade my TPS2024B. I am looking for a modern 4ch DSO for under $2k USD that can be used to capture CAN Bus ,LIN Bus and Flex ray signals of the control unit interfaces as well as capture signals of the embedded side, MCU I/O, etc..
What's out there that's up to the task?
Thanks for any advice.
Offline bdunham7
Re: DSO Recommendation
« Reply #1 on: December 07, 2023, 04:20:27 pm »
The first, most obvious point is that there isn't anything in your price range that is going to have the unique isolation characteristics of your TPS2024B.  I have a TPS 2024 and still use it regularly, so in any case I'd suggest you not throw it out.  Or if you do, please let us know the location of your dumpster!
If the isolation isn't an issue, then the Siglent 2104X Plus is $1399 and there is a sale right now on an analysis bundle that has a 16-channel logic probe and all of the decoding options included for $266.  This is what I have, and if you haven't used modern DSOs like this the increase in capabilities over your TPS will be mind-blowing.  However, it will require some learning and adapting as well as tolerating the occasional bug.
https://siglentna.com/news-article/permanent-analysis-bundle-on-your-new-oscilloscope/?pdf=40323
The following users thanked this post: 9s12
Online nctnico
« Reply #2 on: December 08, 2023, 07:00:00 pm »
I'd take a look at Micsig's ATO series as these have some specific features for automotive use.
Online Andreas
« Reply #3 on: December 09, 2023, 04:03:18 pm »
Hello,
what about a PicoScope 4425A?
https://www.picoauto.com/products/automotive-oscilloscope-kit/picoscope-4000-series-specifications
it has "floating" inputs (+/- 30V against each other Ground pin) which should be plenty for most 12/24 V systems.
with best regards
Andreas
Offline chrisb741
« Reply #4 on: December 10, 2023, 06:32:52 pm »
Where can I get a compatible logic probe for this scope? or is the official one the only one that works?
« Reply #5 on: December 10, 2023, 06:55:22 pm »
The SPL2016 probe is supplied as part of the promo package bundle with the purchase of selected new DSO's:
https://int.siglent.com/info/detail-74.html
Normal price is USD369 for just the probe.
« Reply #6 on: December 10, 2023, 07:38:08 pm »
Check the link to the DIY LA probe thread in the POI list here:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/
