Author Topic: Defective SSA3021X Plus  (Read 391 times)
Offline RandySTopic starter
« on: June 30, 2024, 02:37:02 pm »
I have a SSA3021X Plus that was purchased new in January of 2023. I've not used it more than a few hours.
When powering up, the display is all white, switches to black, then back to white again. After a few more seconds, the intensity slowly starts decreasing and it ends up looking like this.
Has anyone else seen this? Suggestions as to where to start troubleshooting? Are the service type manuals available?
Thanks!!
« Last Edit: June 30, 2024, 02:40:00 pm by RandyS »
Offline coromonadalix
Re: Defective SSA3021X Plus
« Reply #1 on: June 30, 2024, 04:18:09 pm »
send a mail  to Tautech  member here ...
« Reply #2 on: June 30, 2024, 04:35:56 pm »
Thanks! Will do.
Randy
Offline KungFuJosh
  • TEAS is real.
« Reply #3 on: June 30, 2024, 06:30:14 pm »
Assuming you didn't buy it on clearance, it should have a 3 year warranty. Contact Siglent NA for support if tautech doesn't have an easy fix.
« Reply #4 on: June 30, 2024, 08:33:31 pm »
https://siglentna.com/service-and-support/
Offline Martin72
  • Testfield Technician
« Reply #5 on: June 30, 2024, 08:36:14 pm »
This looks like a hardware defect, apart from sending it in there won't be much you can do.
(Kierkegaard)
