Author Topic: Has anyone here built a 'scope cart?  (Read 4797 times)
Offline cvanc
Re: Has anyone here built a 'scope cart?
« Reply #25 on: August 27, 2018, 01:14:51 pm »
What city are you in?  I've got a Tek cart you can have but you gotta come pick it up.  I'm in Chicago.
PM sent!
...And replied to.  Come help me clean out my garage  :-DD
Offline tkamiya
« Reply #26 on: August 27, 2018, 04:16:37 pm »
This is mine.   When equipment gets too tall, I put strap around it so it won't topple over.  I make extensive use of this setup for test gear and in-progress projects.  On back of each one, there is a 3 tap extension cord.  Plywood is 1/2" kind.  I removed handles from carts because it's more trouble than worth.
« Last Edit: August 27, 2018, 04:20:39 pm by tkamiya »
Offline BillB
« Reply #27 on: August 27, 2018, 04:45:53 pm »
For some of the boat anchors I've seen around I'd use:
