Author Topic: Decent benchtop multimeter for beginner?  (Read 14146 times)
Offline Fungus
Re: Decent benchtop multimeter for beginner?
« Reply #75 on: August 12, 2024, 06:22:28 pm »
In that case there is no need to pay for an expensive bench meter, sounds like even a 4.5 digit benchtop will do the job.
I think the requirement is for something that runs on mains with fast autoranging.
All the talk of traceable calibration is a red herring.
Offline Fungus
« Reply #76 on: August 12, 2024, 06:31:01 pm »
I get it, you want fast continuity. I just have an Uni-t 61E on my desk, that I grab most of the time to take quick measurements, not the desktop one.
If you want fast continuity get a $7 Aneng DT9205A.
https://www.aliexpress.com/item/1005005221439318.html
It also has a really bright continuity LED on the front, bright enough to be useful, and it's as fast as anything else I own even with the supplied probes.
nb. There's another meter with the same model number. The one I have is square with colored side panels, not colored top/bottom.
(I should maybe get on of the others to see if it's the same)
« Last Edit: August 12, 2024, 06:35:15 pm by Fungus »
Offline bdunham7
« Reply #77 on: August 12, 2024, 07:02:22 pm »
OK, then I guess he wants a Fluke 8842A set to the "M" reading rate...
Offline Aldo22
« Reply #78 on: August 12, 2024, 07:13:49 pm »
Offline nctnico
« Reply #79 on: August 12, 2024, 07:14:50 pm »
Both suggestions completely ignore what the OP is looking for  :palm:
Offline uargo
« Reply #80 on: August 12, 2024, 08:42:36 pm »
If you find the OWON XDM3041 for less than 350€ it can be a good option (be careful not to find the XDM2041)
The XDM3041 4.5 digits, precision 0.02, AC voltage to 100khz, AC current to 10khz, Bar meter, histogram, trend chart, Max. Min. value, average value, standard deviation,
DB / DBm, Pass / Fail
external trigger, 4-wire measurements, RJ45.
For 400€ the Siglent SDM3045X is better
For 400€ you also have the Rigol DM858E 5.5 digits precision 0.06, AC voltage and current only 8khz, only measures up to 3 A, I see it cut down but it does have a huge touch screen
and for a little more the SDM3055 is the best
Online J-R
« Reply #81 on: August 12, 2024, 10:03:54 pm »
The Rigol DM800 series still has major unresolved bugs, some in hardware, so should not be a recommendation.
Offline corey
« Reply #82 on: August 12, 2024, 11:55:18 pm »
Question, related but doesn't help the OP: I see a whole lot of 2nd hand Keysight/HP benchtop DMMs on Ebay for ~AU$1000-1500 (incl postage), such as the 34401A, U3402A, etc. Why would anyone buy one of those (old) units when one could buy a SDM3055 for ~AU$730? I haven't compared the specs but is it just in the accuracy/tracking?
Online KungFuJosh
  • TEAS is real.
« Reply #83 on: August 12, 2024, 11:58:19 pm »
Mostly just eBay insanity. I would never spend that much for old used and abused gear with less going for them.
You could buy a new SDM3065X or a new DMM6500 for what people are asking for lesser old gear.
Offline Fungus
« Reply #84 on: August 13, 2024, 12:14:52 am »
I wasn't replying to OP, I was replying to "I keep a UT61E around for continuity testing" guy.
Offline CaptainBucko
« Reply #85 on: August 13, 2024, 02:22:45 am »
The OWON XDM1041 is very good value for money overall, but it has several things:
Don't get me wrong, for that price it offers great value for money. But it is not on par with the SDM3055.
I own an Owon 1041. Yes the auto range speed is a bit annoying, so I mostly leave it in fast update mode.
I bought it because of its small form factor (I wanted a DMM to be permanently mounted on the wall board of my work bench), and easy to read display.
The Owon 1401 was $159 AUD from Amazon. The Siglent is $726 AUD. So it's a bit of a Fiat vs Ferrari decision.
Online J-R
« Reply #86 on: August 13, 2024, 02:57:33 am »
It's not unusual for an item no longer made to increase in value, whether it's test equipment, cars or whatever.  The 34401A has a long history, is discussed on the forums quite a bit, and there are valid reasons why someone would be willing to pay a bit more for one, primarily accuracy and stability due to aging, but also maybe just nostalgia.  Common prices are $350-$500 USD.  Higher prices could be due to a recent calibration or a model in good condition, and of course in the case of eBay there are always listings that are inflated for the common go-to reasons you can read about online.
The DMM6500 goes for $1,600 USD, so not sure how that would be a reasonable comparison.
SDM3065X is $745 USD, but it's known that Siglent uses an un-aged LM399 so there could be some drift over time.  This is probably fine if you pay for yearly calibrations, but it probably defeats the purpose of those digits if you don't (or have a way to verify it).
There are a wide range of forum users here, and not everyone is looking for the same thing.  Which can lead to some unnecessary back and forth, so it's important to list out priorities when asking for purchasing advice.
Online EEVblog
« Reply #87 on: August 13, 2024, 03:54:16 am »
I'll just drop this here  8)
The following users thanked this post: egonotto, Fungus
Offline ledtester
« Reply #88 on: August 13, 2024, 04:06:51 am »
Is Ali express legit?
https://www.aliexpress.us/item/3256806417536519.html?src=google&aff_fcid=552b5cb0b38c429d8292f81a744a1dc7-1721577183452-07993-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=552b5cb0b38c429d8292f81a744a1dc7-1721577183452-07993-UneMJZVf&terminal_id=dc38be48f2bf4b389ee4a2ebb6d24988&afSmartRedirect=n&gatewayAdapt=glo2usa
AliExpress is legit, personally had no problems myself. But it's really up to the individual seller.
AliExpress is legit but if the unit is defective the best you are going to get is financial compensation - which might be 100% (probably doesn't include shipping) but that's really up to the vendor. And don't expect to be able to return it just because you don't like it.
Offline tszaboo
« Reply #89 on: August 13, 2024, 08:57:26 am »
They have two targets. One is looking for a perfect condition calibrated gear to replace a failed one in a test setup. They are willing to pay more because writing test scripts changing cables is expensive.
The other is people who want to have a decent DMM at home to take measurements. These are sold for ~400 EUR.
Offline Phil1977
« Reply #91 on: August 13, 2024, 10:06:51 am »
And many customers just want you to use certain type of measuring equipment. If you say you did some qualification tests with e.g. a Siglent then your results are automatically doubted. Some people trust names more than calibration certificates.
The following users thanked this post: Fungus
Offline coromonadalix
« Reply #92 on: August 13, 2024, 11:54:44 am »
you had Micronta bench meters, you had 2 version of them,  compact bench meters and useful
and can be purchased for low prices outside the vintage effect plaguing many sites
https://www.ebay.com/itm/315655169172?
or unless you're driven mad getting more digits ??
3468 3478 ... 3478 with enhanced functions ... thread here ...
but as soon you get outside 4.5 digits, you'll see price rise pretty fast ... unless  you stick  for the uni-t  vichy victor  kinda cheap ones  ...
establish your needs, and save money to get yourself a good one ...  but keep in mind there is no perfect meter with all functions
but if you need calibrated stuff,  you'll need to go with known brands $$    but repair side is another story
Offline maralb
« Reply #93 on: August 13, 2024, 03:16:17 pm »
GW-Instek GDM-8245 might be another option.
https://www.gwinstek.com/en-US/products/detail/GDM-8245
It suits the budget. If you don't need any gimmicks it is a decent device.
« Last Edit: August 14, 2024, 06:36:36 am by maralb »
Online KungFuJosh
  • TEAS is real.
« Reply #94 on: August 13, 2024, 03:24:36 pm »
Why do companies still make bench DMMs with those terrible screens? I hate that. Information display is terrible.
How about the ability to track statistics?
Or take screenshots?
Or connect to a program like TestController and track data over time remotely?
Online KungFuJosh
  • TEAS is real.
« Reply #95 on: August 13, 2024, 04:11:36 pm »
Really I’d like the Siglent 3065x
That's an excellent choice. I've been very happy with mine, and the stability/accuracy are excellent.
Offline live2fish88Topic starter
« Reply #96 on: August 14, 2024, 02:22:24 am »
This is my solution until I can settle on a bench top meter. Designed it in CAD and printed it on my 3D printer. Can be attached using double sided adhesive or screws.
Offline BeBuLamar
« Reply #97 on: August 14, 2024, 10:40:11 am »
I have the Fluke 8050A which is just about as accurate as my best handheld Flluke 289. It's cheap. Just doesn't have a lot of function but generally enough for what I need.
Offline Antonio90
« Reply #98 on: August 14, 2024, 11:06:43 am »
I have one, and it is good at what it does. It lacks continuity though, otherwise it would probably be used much more.
I's also ridiculously expensive in Europe. Someone in Italy seems to think it is worth around €130-150, plus shipping, go figure.
For less than $50 and working, it's a nice, very stable meter for the price.
Offline BeBuLamar
« Reply #99 on: August 14, 2024, 11:39:25 am »
I got mine around 1995 for $25 from a company that made telephone switchboard which went out of business. I never had it calibrated but it was calibrated a few months before I got it.
