If you find the OWON XDM3041 for less than 350€ it can be a good option (be careful not to find the XDM2041)
The XDM3041 4.5 digits, precision 0.02, AC voltage to 100khz, AC current to 10khz, Bar meter, histogram, trend chart, Max. Min. value, average value, standard deviation,
DB / DBm, Pass / Fail
external trigger, 4-wire measurements, RJ45.
For 400€ the Siglent SDM3045X is better
For 400€ you also have the Rigol DM858E 5.5 digits precision 0.06, AC voltage and current only 8khz, only measures up to 3 A, I see it cut down but it does have a huge touch screen
and for a little more the SDM3055 is the best
