Author Topic: Decent benchtop multimeter for beginner?  (Read 12767 times)
Offline live2fish88Topic starter
« on: August 10, 2024, 02:31:20 pm »
Hey guys. Looking for a new bench top meter. I don’t feel comfortable buying used unless from a reputable seller (but still prefer new). I have handhelds but would like a dedicated bench top unit. Trying to keep the price $300 or below.
Online KungFuJosh
  • TEAS is real.
Re: Decent benchtop multimeter for beginner?
« Reply #1 on: August 10, 2024, 02:34:46 pm »
For $300, you're better off getting something used. For $400, you can get a brand new SDM3045X.
Offline wasedadoc
« Reply #2 on: August 10, 2024, 02:41:19 pm »
Do you want a benchtop for extra digits or just better aesthetics and ergonomics? Bigger, brighter digits etc.
« Last Edit: August 10, 2024, 03:36:21 pm by wasedadoc »
Offline nctnico
« Reply #3 on: August 10, 2024, 02:43:36 pm »
I'm planning on getting / trying a UT8805E from Uni-T. Otherwise the cheaper VC8145 is a good choice for being a no-nonsense bench DMM although the auto-ranging is a bit slow on these. I have been using the VC8145 for over a decade already as a daily driver.
« Reply #4 on: August 10, 2024, 03:13:35 pm »
I saw the 3045x, 3055 and uni-t 8803e. Was wondering if cheaper was worth it or if I should pay more.
Online wraper
  • Country: lv
« Reply #5 on: August 10, 2024, 03:19:32 pm »
I suggest you don't bother with these whatsoever. Budget bench multimeters are significantly worse than portable meters sold for the same price. For example UNI-T UT8803E that was mentioned is about as good as $40 or even cheaper portable meter.
Online KungFuJosh
  • TEAS is real.
« Reply #6 on: August 10, 2024, 03:21:59 pm »
The SDM3045X is an EXCELLENT meter. I have mine upgraded to SDM3055X-E, but that's not possible (yet?) on all hardware versions (newer versions have a different firmware requirement).
In either case, it's a serious meter.
Offline nctnico
« Reply #7 on: August 10, 2024, 03:28:32 pm »
The point is not the features but having a stackable, mains powered meter. Ofcourse you are going to pay extra for the bigger casing and mains power supply. And likely the volumes are lower so your share of the NRE costs are higher.
« Last Edit: August 10, 2024, 03:34:59 pm by nctnico »
The following users thanked this post: jusaca
Offline BeBuLamar
« Reply #8 on: August 10, 2024, 03:31:34 pm »
If I want a benchtop it's for accuracy otherwise I prefer the handheld. More convenient to use.
Online wraper
  • Country: lv
« Reply #9 on: August 10, 2024, 03:33:53 pm »
OP did not say why he wants one, IMHO a beginner does not need one, especially on a tight budget. Mains powered is barely in advantage, batteries last for a very long time. And you'll make even less space on your likely cramped bench. There way more sensible tools that money can be spent on.
The following users thanked this post: voltsandjolts, Aldo22
Online wraper
  • Country: lv
« Reply #10 on: August 10, 2024, 03:35:46 pm »
It's literally less accuracy for the price. Unless you spend at least double of your budget, there won't be better accuracy than in portable meters.
Offline wasedadoc
« Reply #11 on: August 10, 2024, 03:44:50 pm »
Things like the $100 Owon XDM1041/1241 are a half way house. Not too big but easy to read upright display. More digits than a typical handheld but not in the $400 league.
The following users thanked this post: luma, RAPo
Online KungFuJosh
  • TEAS is real.
« Reply #12 on: August 10, 2024, 04:06:24 pm »
The SDM3045X is a 66,000 count DMM firmware limited on what's actually 220,000 count hardware. DC accuracy is 0.06% + 8 counts. AC accuracy depends on voltage range and frequency, but the worst accuracy is 3% + 40 counts; best case is 0.6% + 10 counts.
The Fluke 87V, is 6,000 counts standard, 19,999 counts in high-resolution mode. DC accuracy is +/- 0.05% + 1 count. AC accuracy is +/- 0.7% + 2 counts. They don't give more detailed accuracy than that, I'm sure they only listed their best accuracy. I'd love to know the true range of accuracy for it.
Bottom line, the Fluke 87V costs more, and is maybe a tiny bit more accurate in a best case scenario, while also giving up other benefits of the less expensive bench meter.
If you match the price of the Fluke 87V, you can buy the SDM3055 instead. 220,000 counts. DC accuracy of 0.015% + 0.004 count. AC accuracy best case 0.2% + 0.05 count; worst case 3% + 0.05 count.
I do agree that doubling his budget gets a much better device. The SDM3065X is 2,200,000 counts. Accuracy± (% of Reading + % of Range). Worst DC accuracy is 0.0055+0.0008.  Best AC accuracy is 0.06+0.04, and worst is 4.00+0.50.
Offline Phil1977
« Reply #13 on: August 10, 2024, 04:16:36 pm »
Yes, the Owon 1x41 are nice with only two serious drawbacks:
- The Autorange is of the "stupid" kind. If a range is exceeded, it first shows Overload, then switches the range, then it shows 0.000, then it shows the actual value. Better meters get this done much faster.
- The AC-ranges switch to zero below 1% of their full range.
Beside that it´s a really convenient form factor. I like especially the 1241 because it needs no power cord and just sits on the table where you need it with a very clear and easy to read display.
What´s also nice in this price class is the SCPI interface.
Offline Fungus
« Reply #14 on: August 10, 2024, 05:28:42 pm »
Many meters do that (or should do that) TRMS converters are inaccurate at low voltage levels.
The following users thanked this post: Mickle T., egonotto
Offline Fungus
« Reply #15 on: August 10, 2024, 05:29:41 pm »
What  do you think is lacking in that meter? Why do you want to change?
Online wraper
  • Country: lv
« Reply #16 on: August 10, 2024, 05:29:47 pm »
And you can buy Brymen BM869S for a little bit more than half the price of SDM3045X. With better resolution, precision and more robust input protection.
Comparing Siglent bench meter with Fluke handheld in this context is disingenuous to say the least.
« Last Edit: August 10, 2024, 05:38:40 pm by wraper »
Online KungFuJosh
  • TEAS is real.
« Reply #17 on: August 10, 2024, 05:46:21 pm »
Agreed, the BM869S is a well respected meter. Again, I think they only list the best case accuracy. I would still like to see accuracy shown across the ranges like Siglent shows. I don't believe for a second these handhelds accuracies are equal across all ranges.
Why? Because it sucks? It's the most popular handheld DMM. Or because all Flukes are overpriced? Fair enough. 😉
All that said, I personally prefer the bench format, as I'm almost always...on my bench.
Offline nctnico
« Reply #18 on: August 10, 2024, 05:49:46 pm »
The slow autoranging is becoming a bit of a nuisance. Other than that there is nothing wrong with it. I'm having quite a hard time finding a replacement without setting a budget.
« Last Edit: August 10, 2024, 05:52:16 pm by nctnico »
Online wraper
  • Country: lv
« Reply #19 on: August 10, 2024, 05:54:00 pm »
Because you compare premium priced industrial (largely electricians) portable meter where precision not a priority with Chinese bench meter.
Online wraper
  • Country: lv
« Reply #20 on: August 10, 2024, 06:01:40 pm »
They shouldn't do that, as it's just lying to try appear better.
Online KungFuJosh
  • TEAS is real.
« Reply #21 on: August 10, 2024, 06:05:27 pm »
Oh, it sucks because it's Chinese. Gotcha. Flukes are also made in Asia. They're "assembled" in the USA. Another part of the Fluke scam. 😉
Anyway, none of it matters since the OP specifically asked for a bench meter. 🤷
Online wraper
  • Country: lv
« Reply #22 on: August 10, 2024, 06:16:53 pm »
Agreed, the BM869S is a well respected meter. Again, I think they only list the best case accuracy. I would still like to see accuracy shown across the ranges like Siglent shows. I don't believe for a second these handhelds accuracies are equal across all ranges.\
You're right, that table shows base accuracy. Here is the full spec http://www.brymen.com/images/ProductsList/BM860s_List/BM860s_Catalog.pdf
SDM3045X is actually better over the range. However it's also over the stated budget quite a bit. There is no chance buying as accurate bench meter for the price of BM869.
Online KungFuJosh
  • TEAS is real.
« Reply #23 on: August 10, 2024, 06:20:23 pm »
Fair enough. But it's a great bench meter for the money. I wouldn't trade any of my bench meters for handhelds...unless I need to bring them somewhere with me. 😉
Another great thing about the Siglent meters, if you can find one used, but still within the 3-year warranty, it can be a great buy.
Online wraper
  • Country: lv
« Reply #24 on: August 10, 2024, 06:23:18 pm »
Nope, because you compare very differently priced market segments. It's like comparing AMD Server CPU with Intel desktop CPU and making a conclusion that Intel offers more performance for the price.
Op said he prefers a handheld meter but wants a bench meter for more accuracy. Which is an opposite of what you'll get for the money if you buy a bench meter within his budget.It was not OP
« Last Edit: August 10, 2024, 07:34:58 pm by wraper »
