Anyone here own, use or have access to Tektronix A6907 or A6909 ?
Much appreciated if you could do me a favor , which are :
- Take a close up shots on the probe's connector body and the inner too, as its proprietary, preferably shot with measurements with caliper. (like length of the connector body, outer diameter, inner diameter, center pin and etc)
- Close up shots at the connector at the unit it self where this probe is connected, ditto with measurements.
- Those probes, all have that white box thingy, what is that ? Are they sort of a circuit box where the cable is connected inside ? Or just like snap-in ferrite that is galvanically isolated to the probe's cable ?
Attached below example photo of the Tek probes with few highlights on the questioned spots.
As this is not a BNC like ordinary scope's probe, does anyone have any idea what this connector is known as ?
Thanks in advance for all the troubles.
